Hood clearance problems...
Old Feb 24, 2002 | 10:22 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Anyone one else come damn close to not being able to have an air cleaner under the hood of a stock Iroc. Mine just BARELY fits, II'm talking thousandths of an inch. It will probably rub when driving.
Old Feb 24, 2002 | 05:56 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey man i was wonderin the same thing. wut manifold do u have? also u said u have a 5spd? is this the stock t-5? hows it holdin up. oh and one more thing did u have to change the flywheel for the pre 86 block? thanks
Old Feb 24, 2002 | 07:44 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I have the Torker II intake on, and it is the stock 5 speed, haven't had a chance to really test it, and I did have to change the flywheel.
Old Feb 24, 2002 | 08:00 PM
Car: 89 Formula
Engine: Carbed 5.7
wut flywheel did u have to use? how many teeth and wut size? also were did u buy it? thanks
Old Feb 24, 2002 | 08:20 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Try a shorter air cleaner.
Old Feb 25, 2002 | 05:52 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
The shorter air cleaners look like crap.
The flywheel I got was off of... I don't know. I'm not sure exactle, but it's alot beefier in size, but a bit smaller diameter, this is so the starter can fit properly, oh and the back of the crank bolt configuration to the flywheel is different on older engines. I'm guessing it's just a manual flywheel from a pre-87 block, could be from a 4-speed I don't know, sorry...
Old Mar 1, 2002 | 11:19 PM
88_RS&86_Z-28's Avatar
dam you got lucky i have a 406 and a edl RPM intake and the smallest air cleaner and i still cant shut my hood so i'am order a 4' cowl induc that way i will have penlty room
Old Mar 2, 2002 | 02:58 AM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
What about using a drop base air cleaner im about to put a new 350 in my iroc and i just bought a RPM performer intake for it and i was wondering if a drop base air cleaner would fit under the hood...........
Old Mar 2, 2002 | 04:32 PM
it should work just fine all i need is like a 1/2 inch and thats all but iam not going to use one cause i dont like how they cover up the carb. so as long as its anything more then a 1/2 drop base you will be fine
Old Mar 7, 2002 | 06:18 PM
Car: 89 Formula
Engine: Carbed 5.7
i am puttin in my carbed 350 and i was thinkin about goin with the edelbrock performer intake cause its not much taller then a stock one so do u think this will fit under my hood just fine? its an 89 formula if that helps
Old Mar 9, 2002 | 12:13 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the performer fits in my 89 rs....not much room left though..
Old Mar 9, 2002 | 01:38 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's all in the air cleaner you use.
Check out this thread on hood clearance
https://www.thirdgen.org/techbb2/sho...threadid=89018
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
