305 TPI to ZZ4 TPI help ???
Old Feb 26, 2002 | 05:05 AM
dakkon's Avatar
I plan on swapping a zz4 for my 305 tpi. I plan on going with aftermarket tpi base & runners, 58mm tb, 24lb injectors, and either slp or edelbrock headers.
My question is i already have a hypertech chip for my 305 would this work or should i just go with the 350 chip, or just get a custom one burned?
Also I was wondering if someone who has already done this could tell me what problems i could run into or new parts i need please help I love my car and want everything to go smoothly!!!
Old Feb 26, 2002 | 02:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to the board.
I haven't done it myself, but a good bud has. The issues you'll face are:
Lack of a cross-over passage in the heads, so you'll have to plumb exhaust up from the headers to the intake to feed the EGR - no big deal, just use a Vette-style base.
Prom - just get a custom one.
Suggestions:
You probably don't need the 24 lb injectors, 22 will work just fine (bud uses 19's, runs better than 24's, but altitude may be a factor there). The 58mm TB is probably overkill as well - 52mm will feed it. Port the plenum, though, and use an AFPR. Go with the SLP headers, you won't regret it.
lt500r55
Sep 1, 2021 01:30 PM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
