Tips N' Tricks
Old Mar 17, 2002 | 10:58 AM
fattie92's Avatar
Tips N' Tricks
Ok guys, my 305 to 350 swap is less than a week away, and with this im gonna need all the help i can get! So i was wondering if everyone can post there TIPS N' TRICKS that they uses for there motor swaps. What works, what doesnt? How to lable stuff, pictures.blah blah blah. Thanks guys!
Old Mar 17, 2002 | 05:07 PM
fattie92's Avatar
oh come on, i know you guys have something to say!!! dont leave me hanging here. i need this swap to go as smooth as possible!! COME ON!! ....please
Old Mar 17, 2002 | 09:20 PM
Guest
Guest
Posts: n/a
Might be a good idea to tell us what sort of induction you have.
I never mark anything. The wiring connections are pretty foolproof, but you can get the vacuum stuff mixed up. Take a couple pics of where the wiring harnesses and vacuum stuff routes, label stuff on masking tape and wrap that around the vacuum lines, and just go to it. If you really want, you can do the wiring the same way. Other than that, should be pretty straighforward as far as engine swaps go. If this is your first, get some help from a friend and plan a couple days for install. Removal should be pretty easy.
Dont forget the ground wires on the back of the heads.
Old Mar 17, 2002 | 09:26 PM
fattie92's Avatar
its a carb 305 to a carb(same qjet) 350
Old Mar 19, 2002 | 10:02 AM
Guest
Guest
Posts: n/a
Definitely mark the vacuum lines, there has to be 10 of them on there or close. Those are the last thing you want to get mixed up. Mark the starter wires and what terminals they go on too, people mix those up alot.
Old Mar 19, 2002 | 01:45 PM
fattie92's Avatar
ok, ill do that.... thanks madmax for actualy trying to help a fellow thirdgen owner out.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
RS Reaper
Sep 27, 2015 07:04 PM
Night rider327
Sep 25, 2015 04:47 AM
