question for all racers out there?
Old Mar 20, 2002 | 03:36 AM
Harley83's Avatar
i have LO3 88 right now and it really sux im not gonna beat it around the bush everyone in there brother has beat my *** hehe. anyways im thinkin of this setup an 86 350 fourbolt out of a pickup gettin it bored .030 over keeping stock connecting rods and crank still fairly decent keith black pistons performer intake 750 cfm carb 3.73 rear end gears 700R-4 tranny rebuild with lockup switch 224/234 duration cam with 2400 stall... now im just gonna port and polish the hell out of the stock heads and put new valves in and springs.. with this setup do u i think i can reach low 13's?? maybe be able to take a 92 5.0 stick? or an ls1 (prolly not).. if ya guys have any suggestions to tell me im crazy or suggest any other mods to achieve lower times i would greatly appreciate it
Old Mar 20, 2002 | 08:38 AM
bhaas's Avatar
Get the XE268H Comp Cam for starters. Ditch the POS 700R4 and get a TH350. Don't go with the 5 speed if you plan on seeing much track time. Maybe get some Vortec heads. They're pretty cheap. $500ish and you should be in the 13's no prob. A posi would help too.
Brad...
Old Mar 20, 2002 | 05:22 PM
mcconahay37's Avatar
I'm going to say keep the 700R4 if you plan on driving on the street or highway, especially since you plan on using 3.73 gears. If you get rid of the overdrive transmission, plan on a lot more frequent fuel stops and for driving 60 on the highway.
Old Mar 21, 2002 | 12:39 PM
xxwarrior36xx's Avatar
I'd say save up and ditch the auto, get a t-56 used off ebay and throw that in there. You would get great fuel and be faster geared. You also could then raise your rear gear and still make it a daily driver.
Old Mar 22, 2002 | 11:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I was with you until you said stock heads (assume same truck the block comes from). Bad idea. Those heads will have small valves and large chambers. Even Vortecs would be better (did I just say that?), but they'd need better springs and a Vortec-specific intake manifold. There are good aftermarket options out there that aren't much of an extra expendature considering what you're gettting.
Where's your exhaust plans? Unless you spend about $700 minimum there, you're wasting your time.
The TH700 is a very good dual-purpose tranny - just needs some help. I'd much rather spend the bucks it takes to get it going than go through the hassles of a TH350 or manual conversion (although I like manning the old oar). For the strip, autos with proper stall are the ticket. For street, OD is sweet.
Suspension - subframe connectors for sure. Other traction help will most likely be needed.
Do you have emissions concerns? Just affects how you do this, not necessarily the final results.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
