305 tpi to 383 TPI
Old Mar 27, 2002 | 01:45 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
305 tpi to 383 TPI
In a couple of weeks I'll finally have my motor and will be ready for the install. I think I have everything lined up but I still have a few things I'm not sure about.
I'm going with alum. AFR's. Some of the wiring harness has ground straps to the heads. I pretty sure I need to relocate them to a conductive point like the block, right? Does this effect any of the other sensore or module's? What else should I consider when going to alum head's?
I will be getting a 350 Knock sensor but do I have to get a 350 ESC module as well? Will my existing ESC work with a 350 knock sensor?
This knock sensor thing is hard to find info on.
Old Mar 27, 2002 | 05:25 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
So far it's a hit and miss with the ESC thing. It may or may not work. Best $ is $74.19 for that rest easy feeling.
To answer my own question with a question.
Why does my stock harness have a ground strap to the head and block? If you have stock iron heads why the need for both ground straps.
Old Mar 27, 2002 | 09:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ground strap on the head is actually grounding the body & computer. The main battery ground cable goes to the engine for the starter. All of the others are just there to make sure the grounding is hard, not a "sneak" ground (through rubber engine mounts, for instance...).
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
