Lt1 swap question
Old Apr 10, 2002 | 12:46 AM
Camaro Kid's Avatar
Lt1 swap question
I am thinking of buying a 93 LT1 with a 1000 miles on it,but i wanted to put my Tpi on it so i dont have to mess with the harness and also the set up i have is better then the LT1s,is this possible to do?,and if so then what do i need to do it?Thanks guys.
Old Apr 10, 2002 | 12:55 AM
Tas's Avatar
Tas
https://www.thirdgen.org/techbb2/sho...threadid=84423
Old Apr 10, 2002 | 03:00 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Your tpi will choke the hell out of that motor I dont care how modded, if you want to retain your harness then just have the intake drilled for a disty and keep the TPI throttle body, problem solved.......
Old Apr 10, 2002 | 03:53 PM
TexasLT1's Avatar
Car: '92 RS
I was just thinking about something, since the optispark sucks so bad, Ive been having quite a few problems with it, could you keep the lt1 intake, drill it out, and put a regular distirutor on there? of course you'd have to make a plug for the timing chain cover. I mean, it seems like it could work, but would the computer even know what to do without the optispark? you'd probably have to switch to an aftermarket computer or something. but I guess it could possibly work. maybe? I dont know, Im just throwing out an idea here.
Old Apr 10, 2002 | 06:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I dont believe you could get the disty to throw out the same pulse as the opti so you'd be stuck to either an existing TPI computer or an aftermarket sbc one such as accel dfi or speedpro fast.
Old Apr 10, 2002 | 07:14 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
The opti sends the low rez signal to make the injectors work. You would need to go with a dfi or something to make it work without it.
Kory
Old Apr 12, 2002 | 12:50 PM
TexasLT1's Avatar
Car: '92 RS
thats kinda what I wast thinking, but I wanted to see what other people thought of it. oh yeah, either of you know what a 4X sensor signal is for the ignition system? Everytime I hookup my scantool I get a code for
Ignition System Fault
4X Signal
I dont remember what code it is, but I think it may be the cause of my problems. any thoughts?
Old Apr 17, 2002 | 02:18 PM
TexasLT1's Avatar
Car: '92 RS
ttt
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
