do headers make engines run cooler?
Old Apr 15, 2002 | 10:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i coulda swore some guy that had a 3rd gen said that his car runs a lot cooler ever since he got headers and a new exhaust.....i just wanna know if this is true or not cuz it may solve my problem........thanks
Old Apr 15, 2002 | 11:10 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
No way.
Old Apr 15, 2002 | 11:18 PM
89_RS_Mike's Avatar
Yes, but only if they are coated headers.
Old Apr 15, 2002 | 11:35 PM
Administrator
I think even when they are coated they still raise temps right?? Maybe not as much though.
Old Apr 15, 2002 | 11:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If they do it's only slightly, they run cooler than manifolds so the under hood temps are a little lower, but nothing that would benefit.
Old Apr 16, 2002 | 01:28 PM
xxwarrior36xx's Avatar
It runs a bit cooler nothing you would notice though.
Old Apr 16, 2002 | 04:41 PM
Marshall89ws6's Avatar
chrome or stainless headers run a hella lot hotter..... header wraps are the way to go!
Old Apr 16, 2002 | 05:15 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
If you have MAD cash then header wraps are great! However for the normal user who doesn't want the heat trapped in his headers so that they melt, coated headers save you money because instead of running for a month then replacing your headers they'll last a LOT longer and have much more benefits with the coating.
Old Apr 16, 2002 | 06:09 PM
well chrome headers are usually jet-hot coated and they still run hot as **** so if u go chrome , wraps are a must and it wont melt jet-hot coated chrome headers..... they will melt any other kind of non-heat treated headers
Old Apr 16, 2002 | 11:36 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
If I understand Matt right...he's asking if the MOTOR runs cooler not the under hood temp. The header will flow exhaust better than the manifolds, therefore the exhaust heat isnt pushed back into the heads because of restriction. The motor should then run cooler. However, the underhood temp will be more because the headers are thinner and have more surface area. Therefore, they lose more heat to the air under the hood then the manifolds would.
Old Apr 17, 2002 | 06:36 PM
DSaylor's Avatar
I know in my case, when I installed headers my coolant temp dropped significantly. Like 30* average.
Has to let a lot more heat out of the engine.
Old Apr 17, 2002 | 07:05 PM
Car: 99 Formula
Axle/Gears: 342
Boy, that was a unknowledgable statement. Header wraps are total junk, they trap moisture speeding up rusting and can collect oil and other deposits and that's a serious fire hazard, it's happened. Headers run cooler than manifolds by the way.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
