Gutted/No Cat Exhaust
Old Apr 25, 2002 | 07:45 PM
iroc_cragg's Avatar
Hey
I am thinking about taking out my cat completly or gutting it so that it still looks like its there. I am just wondering if I remove it if its gonna wreak somthing or mess somthing up. and will there be a sound difference or anything like that. I heard that if ur cat is cloged it will make ur engine run hotter is that true.
So should I gut my cat or no...What are the benefits and what are the disadvantages.
Old Apr 25, 2002 | 07:57 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Some people say that a gutted cat will disturb the airflow from it's shape. I can personal vouch that a gutted cat makes your exhaust sound hallow, if I ever do it to mine I'm just gonna replace the cat with a piece of pipe. Should make the exhaust a lil louder without a cat....
Old Apr 25, 2002 | 07:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Why not just buy a hi-flo one? Or put a straight pipe in its place, unless you have visual emission checks.
Old Apr 25, 2002 | 08:00 PM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
i gutted mine and it sounds great. had to keep it on for visual inspection. it did increase the volume some, and with my flowmaster it sounds mean as hell.
Old Apr 27, 2002 | 06:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
straight pipe it. i have had both on the exact same exhaust setup the straight pipe was louder and meaner sounder. the gutted cat is not anywhere near as loud and it sounds like *** with the hollowness. getting fixed soon though
Old Apr 27, 2002 | 10:53 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Not sure if you need it for looks, but if you do then gut it and put a straight pipe inside of it. If you don't need one then remove it and put a pipe in its place. A good cat is just restrictive, not sure if HP would be gained if removed, unless it was bad. Yes your motor runs hotter with a bad one, the hot air doesn't leave your front pipes as fast.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
Tarizza
Sep 24, 2015 12:57 PM
Camaro_383
Sep 11, 2015 11:28 PM
