popping when i rev eng
just wondering, when i rev the motor, i get a poping sound from under the car, like its back firing. possibilities of problem before i dive into fixing it
Car: 99 Formula
Axle/Gears: 342
If it's coming from the tail pipes, that might be normal. Though if it's under the car, sounds like an exhaust leak, do you have any ticking sounds that increase with rpm?
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Also look for black marks around connections mainly, but all over as well. The black is carbon, and will be a leak.
thats what i figures
there is occasionally a ticking along with the reving. the exhaust and engine need an overhaul any way, just want to know if people have had this/ what it was
there is occasionally a ticking along with the reving. the exhaust and engine need an overhaul any way, just want to know if people have had this/ what it was Senior Member
Not sure what you have for mods, but if you have hedders, you may just need to tighten down the bolts. But it does sound like a leak, right off of the head, that is where I would start checking. A valve ticks all of the time I think, not sure.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if it's all stock and still has the AIR that's why it does it. all my emmissions equipped vehicles have that popping noise coming out of the exhaust when i rev & let of the gas above 3,000.
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Mine pops when the revs goes down and the car is cold. When the car is warm the revs rumble down. I think it sounds awesome and so do the people that hear my car. I think mine is coming from have a hi-flo cat though.
RedLeader289
May 28, 2019 01:47 PM
