3inch y-pipe > 2 1/2 inch y-pipe?
Old May 6, 2002 | 06:46 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
What are the advantages of hacing a 3 inch y-pipe, i think im gonna hae a shop make a 3 inch y-pipe and ill send the hedman y-pipe tha ti ahv eback to jegs. Will a 3 inch decrease performance on my 305 or increase?
Old May 6, 2002 | 06:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't see a 3" y-pipe helping if you don't have a 3" cat-back.
Old May 6, 2002 | 09:38 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Go with the 3" custom. And like Mark said, it won't help if you don't have a 3" catback to go along with it.
Old May 6, 2002 | 09:51 PM
iroc_cragg's Avatar
Mark
With ur Hooker catback... and all hooker catbacks isnt it a 3" pipe. If its a 3" pipe do u have to have a 3" Y Pipe or can u go with 2 1/2" Y Pipe. What are the effects of a 2 1/2" and a 3" on a 3" Cat.
What size Y Pipe did u use mark.
Old May 6, 2002 | 10:12 PM
Car: 99 Formula
Axle/Gears: 342
Yes, all hooker cat-backs are 3".
As far as y-pipe, a 3" would definately help with a 3" catback. As far as what I'm using, honestly I don't think it's 3", it seems smaller than my I-pipe, and I don't think many TES headers come with 3" unfortunately. I bought headers when I had the 305.
Old May 6, 2002 | 10:13 PM
SlowStangEater's Avatar
Originally posted by iroc_cragg
Mark
Because it restricts back down to 2 1/2 you will lose a little power and also gets a little hotter but other than that its nothing to big! But you want the full exhaust! Its the best way to go and it will always be there unlike an engine you may want to swap!
Old May 6, 2002 | 10:15 PM
Hey mark Will the Edelbrock 3" Y pipe fit with the hooker headers or not? IF so that would be a cheap route.
Old May 6, 2002 | 10:17 PM
iroc_cragg's Avatar
Ok
I am planning on getting hookers Catback which is 3" pipes. So for the hooker catback to perform its best I will need a 3" Y pipe right. Does anyone know if the hooker supercomp shorty headers come with a Y pipe. I am sure they do. But do they come with a 3" pipe or a 2 1/2" Pipe. I need a 3" pipe. Correct.
Old May 6, 2002 | 10:19 PM
Ok
Thats what Im wondering too. Thats why I wonder if The edelbrock one is compatible with Hooker. I have yet to find a Hooker 3" y-pipe. You could probably make your own. However it would require welding and a pipe bender. Lots of work.
Old May 6, 2002 | 10:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
they come with a ypipe and feature a 1.9" collector
Old May 6, 2002 | 10:29 PM
iroc_cragg's Avatar
Whats size Y Pipe though. Is it a 3" or a 2 1/2"
Old May 6, 2002 | 10:30 PM
Car: 99 Formula
Axle/Gears: 342
Call summit and ask which TES headers come with a 3" y-pipe, I thought one of them did, but I'm not sure which. I don't think Edelbrock sells just the y-pipe.
Old May 6, 2002 | 11:03 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I was told by Summit a while back that you can get just the Y-pipe if need be but it has to be ordered from Edelbrock and takes a bit to come in.
Also, my TES has a 3" Y-pipe. I think if you order a TES for a L98 or LB9 car it will come with the 3" Y-pipe and if you go for a TES kit for a LG4 or L69 it won't (not that either one can't be made to work) - but don't qoute me on that. All I know is that the kit for my 87 L98 has a 3" Y and I have also seen the ones for various years of LB9s and they have 3" Ys as well.
Old May 7, 2002 | 12:42 PM
gruveb's Avatar
Car: 1989 IROC-1
Hooker doesn't make a cat back system for an 84 Z with HO!
That bites. What's the difference in the exhaust system in an LG4 and an L69?
Do they have one that will work?
I'm thinking that I'm going with dual exhaust...but I'm still weighting my options.
Old May 7, 2002 | 11:34 PM
kfoley's Avatar
Car: '85 Z28
You can just get the cheapest Hooker catback (83-85 305 HO, $199), the only difference with it is that it doesn't have a flange for the cat on it. This isn't a big deal though, all you'll have to do is weld it to the cat (if you have one). As for the difference between the LG4 and L69 exhaust is that the L69 isn't quite as restrictive as the LG4, but it can definitely be improved upon.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
