mac performance exhaust
Old May 8, 2002 | 03:05 PM
SMOKEN's Avatar
just got my piece in from mac performance it is a pipe that replaces the cat the car is really loud now and it feels a little quicker . i was told that the 305 with the 350 exhaust has the 350 cam . by the way it a 1986 305 tpi ws6 best time on g tech was 15.8 at 87 mph with the borg warner 9 bolt 2.77
Old May 8, 2002 | 04:55 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
So you just got a 'test pipe' kinda thing? What's the rest of your exhaust? Stock i'm guessin?
Old May 8, 2002 | 05:24 PM
SMOKEN's Avatar
ITS THE SAME AS AS THE L98 350 THATS WHAT THE MECHANIC SAID HE SAID THERE ISN'T ANY BETTER THAN WHAT I GOT
Old May 8, 2002 | 08:55 PM
steve8586iroc's Avatar
Smoken, the 86 tpi has a 2 3/4" exshaust system and is not mandrally bent. This system flows ok as is but a good custom y-pipe would help a lot. As far as the cam is concerned it is the peanut cam of the tpi world. The 85 305tpi makes 25hp more than the 86 and it's all the cams fault, everything else is the same except the 85 ecm, which is not as good as the 86 ecm. If you want to make some extra power on the cheap I would suggest a cam swap, headers and a y-pipe. Those three mods could net you around 50hp over the stock 190 it's rated at now, maybe more.
Steve
Old May 10, 2002 | 10:24 PM
SMOKEN's Avatar
would i have to change the exhaust manifolds to put this y pipe in if not where do i get this y pipe
thanks
Old May 11, 2002 | 12:09 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
You would not have to change manifolds with a slp y-pipe.I had one on my old car which was an 86 iroc with a 305 tpi.I would'nt suggest it to you though.It was about 200 dollars and the gains were minimal.Get a different cam and headers,the work will be worth it.
Hotrodboba400
Dec 10, 2019 07:07 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
