SLP header pics
Old May 9, 2002 | 10:49 AM
tpi_roc's Avatar
SLP header pics
Anybody have pictures of intsalled SLP headers?
I'd love to see them.
Old May 9, 2002 | 12:30 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
https://www.thirdgen.org/techbb2/sho...threadid=98211
Old May 9, 2002 | 12:36 PM
tpi_roc's Avatar
Ouch
So it doesn't look like im goign to be able to drop in the engine with the headers attached huh?
Old May 9, 2002 | 12:46 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
The collectors have maybe 1/2 inch of clearance around them. If you do try it, I'd make sure the tranny and distributor is off to have the most room to snake it around the frame. (Read: it'd be easier without the headers in. )
Old May 9, 2002 | 12:50 PM
tpi_roc's Avatar
well the distributor has to come out for an engine removal/install so thats no problem...
Is your car a TA or Camaro?
I have a camaro, i wonder the the frame rails/steering column location would be any different between the two.
I was really looking forward to a 'drop the engine in with headers on' scenerio just like manifolds... Guess we'll see saturday
Old May 9, 2002 | 01:05 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
*points to sig* Camaro.
It might be entirely possible. I've never taken the engine out, so I don't have any personal experience, but it looks like the collectors might smack into the crossmember if you put it in with the engine tilted back so the tranny clears. But hey, if it works for you, let the rest of us know.
Old May 9, 2002 | 01:09 PM
tpi_roc's Avatar
Will do
Old May 9, 2002 | 01:34 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, the headers aren't the same, but I dropped my engine in with the TES headers on it. It took some twisting and turning to get it past that stupid A/C heater box, but other than that it went in alright. I suggest taking the wiper motor assembly off as that got in the way a bit too.
Old May 9, 2002 | 01:37 PM
tpi_roc's Avatar
I no longer have AC so i know the passenger side will be a cake walk.
But i have all my brake stuff and my steering column in
Old May 9, 2002 | 08:21 PM
Arron-82ta's Avatar
I installed my slp headers before i droped in the engine and trans and had no problems. I did leave the plastic which they were shipped in on, so i wouldnt scracth them up though.
Old May 9, 2002 | 08:23 PM
tpi_roc's Avatar
sweet
I hope im as lucky
Old May 12, 2002 | 12:35 AM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Heres the driver's side but dont mind my filthy engine compartment. I wish I had sprung for the coating but I was tapped and it was all I could do to get the headers at all....
Old May 13, 2002 | 04:07 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Dropped the motor with the pass side on and the drivers side I had to have the engine tilted slightly up to clear with the steering shaft in.
Old May 13, 2002 | 04:10 PM
tpi_roc's Avatar
I'd be currious if your heads had different dimensions being an lt1 and all.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
mantaguy
Sep 2, 2015 10:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
