Throwing Code After cat removal????
Old May 18, 2002 | 10:33 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Ok, I cut the cat off today to add another step in my moneyless exhaust project. I also pinched the air tube closed for the smog pump. It ran fine and still does but about 5 hrs later (only 1 driving) my service engine light came on so i pulled into a parking lot popped the hood and looked everything over and it looked fine. Started it back up and the light is gone and hasnt came back yet. Any ideas anyone?
Old May 19, 2002 | 11:05 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mine never threw a code but i didnt pinch the tube shut just left it open and dangling
Old May 21, 2002 | 12:05 AM
budda's Avatar
My first suggestion:
Take your smog pump and reverse the direction of the belt on it. I"m telling ya, this makes horepower. Where it hooks to the headers, undo that and plumb it using gutter helmets to keep the leaves out of the induction systemax at high rates of speed... 50-60 mph. Connect the in coming air pump tube to oil pan so that it removes the excess oil from the windage array! This will create a pressuration on the downstroke and a vaccum on the upstroke... upon removal this leads to a unanimous putty fart!
Old May 21, 2002 | 07:06 PM
Omar's Avatar
Why dont you pull the code, and post it. Then we can tell you what the ECM didnt like.
Old May 22, 2002 | 09:04 PM
Car: 89 Camaro RS
Engine: 305 TBI
I would but I don't have a code reader.
Old May 23, 2002 | 09:02 PM
Omar's Avatar
All you need is a paperclip. Do a search and you will find the info.
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
