Hedman Headers clearance problem.
Old May 21, 2002 | 09:50 PM
exdog's Avatar
Car: 91 RS
Engine: TBI 350
Finally got my headers in this weekend. OMG what a difference that made. Can't keep the *** end on the road now. However I have a clearance problem on the passenger side. The header is sitting on the frame / fender well hard and it is causin the top not to seal good obviously causing a small leak. If I hold a lighter over the top of the header it flickers over the 2 center exhaust ports. What would cause this? I am going to put in a new set of motor mounts in the morning to see if it's just sagging, but theres not much play room there.
Old May 21, 2002 | 10:09 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
i just put the 350HO into my camaro a few days ago, my clearance is a little better than that, although it is touching the fuel lines. are you running a copper gasket? paper probably winds up crunching down thinner. i have brand new motor mounts too. here are a few pics:
Old May 26, 2002 | 11:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i have no clearence problems with those heades
z 28 jari
Sep 14, 2021 10:03 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
383cam
Sep 9, 2015 06:01 AM
