CATCO cat or hollowed out cat??
I have an 88' iroc-z 350TPI single 3inch Random Technology cat back exhaust and right now the catalytic is hallowed out and it sounds like a gargling garbage truck i think i should put on a Catco high flow cat?? Do i even have enough back pressure right now with a hallowed out cat, will the catco cat slow me down, iam running 14.025 now, want to be in the 13's THANKS ANYONE
Car: 99 Formula
Axle/Gears: 342
Originally posted by Mohammed
If you don’t have emission lows where you live, gut the damn thing
The cat is already gutted and the car sounds like a loud garbage truck, with the random technology 3inch cat back! Will the catco cat make it sound any better like a throughty flowmaster sound??
Originally posted by brodyscamaro
straight pipe it
straight pipe it
however, this isn't such a good idea, putting a pipe through your cat, UNLESS you have a welder, and can weld the pipe that u are sticking through ur cat TO your cat.. especialy if you did it the way i did.. if your confused look at the pic below
in my setup.. i clamped (soon to be welded) the new pipe to the y-pipe, and bolted the cat to the rear exhaust section (cat back).. and slowly they started to seperate, the new pipe was pulling out from the cat, creating a BIG leak... so after I J.B. welding it twice, i think it finaly stopped coming apart.... But i would strongly suggest getting it welded.. Other wise its not worth it..
Car: 92 Camaro RS
Engine: 305 TBI
Gutted cats sound like crap, I know because I had one for awhile, go with a straight pipe or get the big cat for it, the cat will quiet it down a lot but not slow it down if it's a good one.
Thanks guys, since i need to pass emissions i just ordered a new direct fit CATCO catalytic converter, i'll let u know if it sounds better, or if it slowed me down or gained, because i feel i have very little if any at all backpressure with a gutted catalytic converter, thanks justin!!!! (P.S. headed to maple grove on friday night to find out)
LT1Formula
Oct 8, 2015 08:34 PM
