Removing AIR system
Old Jun 13, 2002 | 09:48 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Removing AIR system
Well, since the previous owner of my car screwed up the AIR pipes (along with a ton of other things), I'm removing the air system when I change the exhaust. I have the big SLP Y-pipe, and am running that directly (no cat) into the flowmaster system that's on the car.
What do I use to plug the AIR fittings in the manifolds? Are they NTP thread? BSP? Metric? Martian?
I wanna plug them nicely if possible, and not screw things up too much. If need be, I'll just snip the AIR fitting just beyond the nut, weld it closed, and reinstall it in all 8 ports. That just sounds like too much work though...
Help?
Old Jun 13, 2002 | 11:14 PM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
just take out each pipe,and get brass plugs to put in their place.thats what ive heard to do,and will be doing it as soon as i get the time to find brass plugs that will fit.does anyone know what size they are by any chance?
Old Jun 13, 2002 | 11:24 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I went down to the hard ware store and picked up some pipe threaded plugs, I think they were 1/4...or maybe a 1/2, get out the ruler
Old Jun 13, 2002 | 11:51 PM
Chevero's Avatar
They were 1/4 NPT (pipe thread) on my stock cast iron Ex. manifolds. The cool ones are a recessed hex (allen wrench) style instead of the crude looking square pipe wrench style.
Old Jun 14, 2002 | 01:37 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
8 plugs, to much work. I took the tube that the four hooked up to and put a brass fitting on that one. easy and the problem is solved. It seems like I am the only one that has thought about doing it like that, am I wrong for doing so??
Old Jun 20, 2002 | 08:14 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I did the weld em up thing on a buick...didn't take too long at all...bout an hour to do the whole thing. Course there was more room to work in the engine bay too.
Old Jun 20, 2002 | 10:42 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
88 bravo,
the reason most take the whole air system out (8 plugs) is to have more room to work on your engine, If I didn't need the room (you must not need the room) then I'd would have either left the air on, or did what you did
Old Jun 23, 2002 | 01:02 PM
goneracin's Avatar
Its some screwball metric pipe, BUT, 1/4 pipe brass pipe plugs work nicley. Just make sure to use brass, as it is soft enough to conform to the thread pitch in the manifolds. I usually use a little hi-temp red silicone on the threads for extra insurance against leaks.
TheExaminer
Aug 26, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
