Please help me with a cheap but good setup
Old Jun 13, 2002 | 10:13 PM
85TPITransAM's Avatar
I am in dire need of a good, yet cheap system. I am interested in mileage and also in aggressive sound. Please post your suggestions and prices. Thanks.....oh I'm running stock exhaust right now.
Old Jun 13, 2002 | 10:40 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
flowtec headers and y-pipe $200,dynomax 3 inch cat back $160,straight pipe for cat $10.I think the exit on the flowtec y-pipe is 2.5 inch,I would cut that off and use a flowmaster y collector or have an exhaust shop make one to use in its place.
Old Jun 14, 2002 | 01:05 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Get the Hedman 1 5/8 Shorties and y-pipe, about $100 each.
Old Jun 14, 2002 | 07:23 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I second the Headmans. I've used Headmans twice before and just installed a set of flowtechs on my 86 TA. The Headmans are better because of the 1 5/8" primary pipe, and I think they are of better quality. It was easier to get at the plugs with the headmans. The #8 plug with the flowtechs is a bit hard to reach.
Old Jun 16, 2002 | 01:45 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hedmans!!!
how about hedman longtubes #68460 104$ dual 3'' pipe 40$ with 2 dynomax bullit mufflers 70$? you will have the best exhaust you can probably get with this setup, the only flaw, groundclearence!! will sound awsome!! there is a link on here with s sound clip with that kind of setup...
total 240$
Old Jun 16, 2002 | 03:37 PM
82z28122's Avatar
I am running hooker comps into 2.5 duals with bullet mufflers coming out infront of the backtires. Very deep.
Old Jun 16, 2002 | 05:41 PM
bilt2serve's Avatar
hey i'm thinking for going slp, but the difference in price from those you'vwe state here are crazy, is it worth it, does it sound much different, and or much difference with power?
Old Jun 16, 2002 | 08:08 PM
badgta's Avatar
Car: 1991 FORMULA
sound clip
here's a link to the sound clip of the bullits..
http://www.in-design.com/~gatorman/s...Kens_97_SS.mpg
when you buy slp's or edelbrock, thats what your buying a name..... just like corvette, you can get the same hp in a camaross or a firehawk, for thousands less... to me it's all about personal preferance, but when you need good hp and low cost, hedman rules!!!
Old Jun 16, 2002 | 10:29 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I think the hooker cat back is like 200....where is MARK at?
Old Jun 16, 2002 | 10:56 PM
82z28122's Avatar
yes but that exhaust doesnt sound half as good if your looking for a very aggressive sounding exhaust.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
onefreakz
May 14, 2018 12:15 PM
dutch930
Sep 11, 2015 06:58 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
