Help, I need a header Gasket
Old Jul 11, 2002 | 03:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My brother said to get exhaust manifold gaskets cause they're thicker. Would this be ok? Also, how do I know if I have square or circle exhaust ports?
Old Jul 11, 2002 | 04:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exhaust manifold gaskets typically have perferrated steel on one side, because of the heat retained by the cast iron. For headers, they typically don't work that well.
Have you tried just putting a bolt in and snugging it up? Or do you know for a fact that the gasket is burnt out?
You have round ports. Squares were the more hi-po versions.
Old Jul 11, 2002 | 05:08 PM
Car: 99 Formula
Axle/Gears: 342
One bolt is missing, another was loose. On the end towards the back I can see the gasket burnt up, like the inside part of the gasket is showing.
Old Jul 17, 2002 | 02:44 PM
3rdgen327's Avatar
on my install of headers i did not use a gasket. i used an heat resistant RTV. i got it from advace auto parts. it was in a pressurized (contence is an off red color)can up by the cah register. i made sure to retorqe all header bolts after each motor run for the first month or so after motor cool down. i have had this seal sence dec of 2001 and no leaks yet. this was a trick i picked up from the local dirt track racers.
Old Jul 17, 2002 | 05:55 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I have heard to soak the gaskets in water to make them swell. Let them dry and then install. Not sure if this works, but you can try. The single gaskets might work alitlle better than the full length gaskets. I have never done the water trick.
Old Jul 17, 2002 | 08:04 PM
Car: 99 Formula
Axle/Gears: 342
I already changed it, but we'll see how it holds up. It wasn't the gaskets fault, the bolt fell out.
Old Jul 18, 2002 | 12:35 PM
3rdgen327's Avatar
if it is the right back bolt you will have to retighten the bolt over and over for a while to try and keep it from burning another gasket. for some reason small block chevy like to loosen that back header tube.
good luck
Old Jul 20, 2002 | 05:58 PM
jeffs82z28's Avatar
Get yourself some Percy's aluminum header gaskets from Summit or Jegs. They are the cat's a$$
I've only had to re-torque them a couple of times during the first week of operation.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
