stock manifolds.. what is the flap for??
Old Jul 17, 2002 | 08:37 PM
KiLLJ0Y
Guest
Posts: n/a
ok so i got flow-tech headers(which kick *** and sound awesome) and while taking off the LG4 manifolds.. i noticed on the passenger side, this wierd flap housing inbetween the Y pipe and the manifold... appears to have been vacum opperated, but my question is...
why the hell would you want to restrict the exhaust flow from the manifold???? what was the point of it???
Old Jul 17, 2002 | 09:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
EFE - "Early Fuel Evaporation".
When the engine is cold, the valve closes, forcing part of the exhaust flow from the passenger bank of cylinders, through a passage in the bottom of the intake manifold to warm the base of the plenum, then out the other side. When the engine warms up a bit, the vacuum is taken off, and the valve opens. Helps the engine run a little better and cleaner when cold.
Been doing it for decades. Have tended away from it in the EFI years.
Old Jul 17, 2002 | 09:23 PM
KiLLJ0Y
Guest
Posts: n/a
its the things that make you go "Hmmm"
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
