Hooker Comp headers, dynomax super converter, and hooker cat-back system?
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Will all of this bolt up to each other if i get the 2 1/2" in and out cat? I want these headers and cat-back system and the converter i might as well get anyway.
Car: 99 Formula
Axle/Gears: 342
No. The I pipe that connects to the cat is 3". So you would have at least need a 3in out cat. But I would strongly suggest to get the 3"yipe and just get a 3" in/out cat.
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
is the hooker cat-back 3" pipe if so i would get that but on the jegs site it says 2.5" that is why i was thinking to get the 2.5 in and out. I know a 3 inch exhaust is key. i would have a custom y built also unless hooker sells one
Transmission: 4L80E/4L80E
Hooker "Comp" shortie headers don't have a y-pipe. You will have to have one fabricated. You could have a 2.5" pipe made, but why dump two 2.5" pipes into one 2.5" constriction?
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
