Hooker LT's and Spohn Torque arm
Old Aug 16, 2002 | 12:31 AM
lexussc94's Avatar
I have Hooker long tube headers and Spohn's torque arm on my car. I need an exhaust setup for this. Will the mufflex y-pipe fit the torque arm's crossmember? Anyone have any ideas for me? Thanks
Old Aug 16, 2002 | 07:26 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
No, the Mufflex Y will not fit with a Spohn crossmember ... not even close.
Tim
Old Sep 13, 2002 | 08:01 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Can the crossmember be grinded to allow the Y-pipe to fit?
Old Sep 29, 2002 | 08:24 PM
lexussc94's Avatar
Would a custom y-pipe be to restricted because of the Spohn Torque arm?
Old Sep 29, 2002 | 10:45 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Agreed on the Spohn CM and Mufflex Y. Me thinks you will need to go custom Y-pipe on that. Grinding away material on the CM is prolly not a good idea.
Old Sep 30, 2002 | 12:43 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have a SPD T-56 x-member (which is the same as the Spohn T-56 x-member) and I'm using a Mufflex TPI-Y (the big one). I notched the x-member where the y-pipe was hitting in a few places. I never cut any welds, but the notches are real close to the welds. Eventhough I notched it, it was still sturdy enough to hang the tranny. But then I went one step further and welded a corner support brace on both sides of the top side of the x-member (the notched area's are on the bottom side). Now, the mufflex y-pipe fit fine and hangs higher than the header collector. (passenger side header collector is the lowest part of my whole exhaust system). Just my $.02
Mike (1bad91Z)
Old Oct 7, 2002 | 09:00 PM
WS6Formula350's Avatar
Where do you get the mufflex y-pipe and will it work for hooker shortie headers???
Old Oct 7, 2002 | 10:11 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You have to order the Mufflex Y-pipe from Mufflex Performance
http://www.mufflex-performance.com/
Just call them up and ask for a (TPI-Y).
And no, it will not work with shorties. That y-pipe is designed to work with Hooker Super Comp Long tube headers with 3in. flanges.
Mike (1bad91Z)
Old Oct 8, 2002 | 04:31 PM
lexussc94's Avatar
Hey 1bad91Z,
You have any pics of that? I would love to see it. I was thinking of making my own y-pipe from the oval tubing that spintech sells.
Thanks, Mike
Old Oct 8, 2002 | 05:08 PM
lexussc94's Avatar
Also anyone know if this would work where the pipe passes the X-memeber (Spohn's)
http://www.drgas.com/photos/frameclearance.jpg
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
