Which would flow better?...
Old Aug 25, 2002 | 02:56 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
lets say I have a 3" straight exhaust...now the question is...what would flow better? A single 3" straight through muffler? or dual 2.5" straight through mufflers? I know the 2.5" inlet wouldnt flow as good as a 3"...but if I put two would it flow as good or better then a single 3"? Thanks in advance.
Old Aug 25, 2002 | 08:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What do you mean by "straight through mufflers"?
Old Aug 25, 2002 | 09:24 PM
jd13's Avatar
I think he means a 3 inch exhaust system with no cats and dual 2.5" with no cats just mufflers.
If that is what you mean, then the 2.5" dual exhaust would flow better.
Old Aug 25, 2002 | 09:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Dual exhaust will outflow single exhaust. Actually 2.25" duals is about = to single 3". But duals are better.
Old Aug 25, 2002 | 09:40 PM
iroc22's Avatar
Oh man not the single vs. dual again....
Old Aug 26, 2002 | 12:53 AM
REVLIMIT's Avatar
Engine: Built L98
nononoono haha I know dual exhaust will flow better then single. What I'm saying is I HAVE a straight 3" exhaust. What will flow better a single 3" straight threw MUFFLER (dynomax race bullet like) or lets say two 2.5" straight threw MUFFLERS (two 2.5" race bullets) Which muffler set up will flow better?
Old Aug 26, 2002 | 09:23 AM
five7kid's Avatar
Answer's the same - dual.
Just please, PLEASE, don't say "Cherry Bomb"...
(It's "through", as in "Going through the motions", not "threw", as in "He threw out the ceremonial 1st pitch". You had it right the first time.)
Old Aug 26, 2002 | 01:21 PM
REVLIMIT's Avatar
Engine: Built L98
nononno hell no! haha I aint putting no cherry bomb! haha...much thanks for the info
Old Aug 26, 2002 | 03:52 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the only thing is if you are running both headers into a 3 inch pipe then split them into dual 2 1/2 mufflers
you might be better off just keeping the single pipe instead
that split to make the dual pipes for the dual mufflers will disrupt the flow a little bit
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Fireslash
Apr 11, 2016 06:43 PM
383backinblack
Oct 14, 2015 08:50 PM
dusterbd
Sep 29, 2015 08:40 AM
