quick fix?
Old Sep 5, 2002 | 08:11 PM
DEATH88305's Avatar
Car: 1988 IROC CAMARO
Engine: 5.0 F.I.
Transmission: 700 R 4
quick fix?
i need a quick fix for my catalytic converter, it has failed and is rattling, but i have no access to a way to fix it till later, the dilemma is our annual cruz night is this saturday n i want to quick fix it, if possable, ne ideas??? its a weld in unit, bummer.....
help............ i got a bucket of bolts rattling under there...
Old Sep 5, 2002 | 08:54 PM
Dragula's Avatar
Sorry......no quick fix other than replacing it!
Old Sep 5, 2002 | 10:34 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
I don't know if you'll want to do this, but here's a way: cut the I-pipe behind the cat, leaving enough room for a clamp. Grab a blunt instrument that will fit in the outlet of the cat and break the insides (is it called a substrate?) into pieces small enough to fit through the outlet. Use the motor to blow out the pieces. Now, use a piece of pipe, (you can often find correct size splices at a parts store) and two clamps to splice the I-pipe back together. I understand, depending on your exhaust you may not want to cut it, but it would get the job done. Thought I'd throw it out there...
Old Sep 6, 2002 | 12:44 AM
DEATH88305's Avatar
Engine: 5.0 F.I.
oh,well,just a try....
kool. thanks! i will try that at work, im a welder fabricator so i have access to the tools, just have to get permission from employer to use shop, if not oh well....... thanks fellas.......
Old Sep 6, 2002 | 09:59 PM
DEATH88305's Avatar
Engine: 5.0 F.I.
FIXIN 4 GOOD....
I GOT PERMISSION TO USE THE SHOP TOMORROW, ILL BE REPLACING THE RESTRICTIVE PIECE OF SH*$!
IM PUTTING A SOLID PIECE OF STRAIT PIPE IN ITS PLACE, IM NEVER SELLING THE CAR SO HEY!!!!!
THANKS AGAIN.........LATE!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
mackjar66
Sep 14, 2015 01:17 PM
