Does anybody have pictures of edelbrock headers with their AIR plugged off?
Old Sep 10, 2002 | 10:27 PM
TBI305Camaro's Avatar
Im probably gonna get a set of the edelbrock headers and i was just wonder how everybody decided to seal the A.I.R hoses off. I dont have A.I.R anymore and due to the ripping and breaking of the A.I.R components its impossible to ever have it again. Anyways I was looking at getting summit part # EDL-6872 which has the slip on 3inch cat. Anyways anyone have pics or suggestion about how to plug the holes? Also do the edelbrock headers come with good bolts and gaskets or not?
Old Sep 11, 2002 | 11:26 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sorry I dont' have pics, I lost them all. But basically, I just used JB Weld to plug them off. I eventually will cut them off.
Old Sep 11, 2002 | 01:21 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I used brass tubing connectors that I drilled and brazed. I can now insert a 1/8 inch exposed thermocouple into any cylinder exhaust stream to make a measure of exhaust temperature for tuning purposes.
Works great though the thermocouples are expensive! When the thermocouple is NOT inserted, I place a stainless steel ball bearing into the collet and tighten for leak-free operation.
Cheers,
Daniel Burk
Old Sep 11, 2002 | 02:36 PM
Car: 99 Formula
Axle/Gears: 342
I was goin to do something similar, but just crimp it at the bottom.
Old Sep 11, 2002 | 02:46 PM
89Irocz23's Avatar
Its kinda hard to see mine but mine are just welded shut.
Attached Thumbnails Does anybody have pictures of edelbrock headers with their AIR plugged off?-26f02-8-27-16
Old Sep 11, 2002 | 03:56 PM
Car: 99 Formula
Axle/Gears: 342
That is the first pic of your motor I've, I think.
Old Sep 11, 2002 | 10:34 PM
Looks easy enough. I just can't find a better header for the price and it actually comes with a decent y pipe. To bad edelbrock is so set of keeping things legal....But if I get the 69 firebird im going to look at tomorrow the 88 will have to take a backseat for along time.
Old Sep 12, 2002 | 08:13 AM
Car: 99 Formula
Axle/Gears: 342
What about the Hooker super comp headers? They're prolly a little better and about the same $.
Old Sep 12, 2002 | 09:10 AM
They are ~$350 but do they come with a 3'' y pipe? And I'm sure they are harder to install than edelbrocks I know my hookers were a pain. Supposedly had to raise the motor but I just took a bunch of stuff off. I just want a decent header with a decent 3'' y pipe. And I think the hooker ***** has me set on getting a hooker catback.
Old Sep 12, 2002 | 09:29 AM
grovier's Avatar
i have dynomax headers looking to find better headers. whats the best size and type of headers should i use. i dont have to use the A.I.R. stuff i ripped it all out. any ideas. oh and to plug up those A.I.R, wholes i just used a set of brass plugs.
Old Sep 12, 2002 | 09:43 AM
87transam5.7tpi's Avatar
do a search for deadtrend1 and go to his site. I'm pretty sure he has edelbrocks and he just welded the holes closed also. hope that helps
Josh
Old Sep 12, 2002 | 10:55 AM
Car: 99 Formula
Axle/Gears: 342
If you already have headers, unless you're tryin to get a few more HP, I'd stick with what you got, unless you can sell them. I don't see 5hp (estimate) worth another $300 bux.
Old Sep 12, 2002 | 03:28 PM
ws6transam's Avatar
I'm going to be doing a test, hopefully next summer. I might try my current exhaust with my new motor on a water brake dyno. Then, I'm going to swap in a set of Hooker long-tube headers and repeat the test. I'm hoping to develop a decent tune with my handy-dandy FLASH PROM, a programmer, Tunercat, and this here #730 speed density ECM that's been laying in a box on my desk since 1997.
Old Sep 12, 2002 | 03:49 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Cut em off, weld shut, grind inside & out flush, send to Jet Hot.
Old Sep 12, 2002 | 10:22 PM
ws6transam's Avatar
Originally posted by Ricktpi
Cut em off, weld shut, grind inside & out flush send to Jet Hot.
If you are going to send to Jet Hot, send 'em a Hooker system! Why spend $200 to coat a $300 set of headers?
The picture above is a pic of what I did to coat my own headers: I stripped off the black paint when they were new, then painted them with VHT1600 in flat aluminum. Two coats, then a couple hour bake in my lab oven at 400 degrees... The headers have not rusted one bit in three seasons, and it only cost me an afternoon and sixteen bucks.
By the way, I bought mine from TPIS for $315, shipping included. I, like you, also ground out the welding bead with the die grinder.
Old Sep 13, 2002 | 09:26 AM
Like Mark said if you have a decent set of headers and a decent y-pipe no point of changing for 5 extra HP. But in my case I have a feeling its going to be alot more than 5hp...since my entire exhaust is so screwed up. Plus I want to go to 3'' because what I plan will need it.
Old Sep 13, 2002 | 09:35 AM
grovier's Avatar
true, when i bought these headers i didnt do much research on them. and since i dont need to run the AIR tubes i can get headers woth out those tubes. i was just curious curious how big of a header i could go. the ones i have on know look small. i have seen some headers for about $150. thats not that bad. the 3 inch pipe does make a whole lot of difference though. i have 3 inch on mine and made a world of diference in power and sound.
Old Sep 13, 2002 | 11:24 AM
Ricktpi's Avatar
Send whatever you have. I wasn't suggesting Edelbrock in perticular. BTW here in PA the sandblasting & paint method lasts about 3 months.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
