True Duals
Old Sep 12, 2002 | 04:06 PM
89Rock's Avatar
True Duals
I am gonna put true duals and hooker headers on my 89 IROC. I need to know if it will screw with the computer. If it does, how can I bypass the computer so it wont? Also, are there any other mods that will need to be done so I can do this? If so please tell me. Thanks
Old Sep 12, 2002 | 04:32 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
if it was me, I'd get a new chip burned, I'm not exactly sure what else you'd have to change other than more fuel, on the 86, I'm going computerless, and the 91 isn't getting many more mods
Old Sep 12, 2002 | 10:26 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
It might run lean when you put the headers and duals on so you might want to bump up the fuel pressure and burn another chip. Not sure what else to do though, I'm a carb guy.
Old Sep 13, 2002 | 05:50 PM
iroc22's Avatar
The increase in flow should not affect the ECM. I'm gonna assume your car is TPI and that means it's a MAF system. It definitely wont affect the computer's thinking. Putting on headers might make it more lean but as mentioned above, just bump up the fuel pressure.
Old Sep 16, 2002 | 11:41 PM
89firechicken's Avatar
i have a question that iv'e been thinking about for a while why do people call it true duals when i was growing up and (im only 20 by the way) i always called them or heard them called duals, dual pipes etc. and usally if you have one pipe go into a muffler with two pipes comming out isnt that called a catback system? i was just wondering what you guys thought. imo i think calling them true duals is stupid it just doesnt sound right. sorry just had to vent a little.
Old Sep 17, 2002 | 12:06 AM
kfoley's Avatar
Car: '85 Z28
Our cars came stock with a single pipe system that looked like dual exhaust at the back of the car. It's called true duals so that it ins't confused with the "fake" dual setup.
Old Sep 17, 2002 | 12:54 AM
otherwise known as a catback system right. so if some on asked you would you say "oh its a hooker cat back" or "im runnnin dual 40 series flowmasters" or would you say " oh yeah i'm runnin a true dual flowmasters" i dont know about you guys but imo that sounds kinda fruity
Old Sep 17, 2002 | 01:55 AM
kfoley's Avatar
Car: '85 Z28
A cat back could have dual tips, or just a single one. I just say I'm running dual hookers, but that usually gets wierd looks.
Old Sep 17, 2002 | 11:19 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I've got full length Headmens and two pipes all the way back to two small Flowmaster race mufflers under the back bumper. I've got an '87 TPI and the only thing I had to do was weld an O2 bung into one of the collectors. No computer mods were necessary, although I'm sure if I had a chip burned it would help even more.
Old Sep 19, 2002 | 09:32 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
kan i put those in a 84 z ho carb or wat
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
