replacing header gaskets, need help
Old Sep 20, 2002 | 07:53 PM
StocRoc's Avatar
I am replacing my header gaskets w/ dead soft aluminum ones and I am having trouble getting the passenger side header back on. I got the first three bolts started, but I can not get the back three towards the firewall started. I have tried moving the header around, but I just can't get them started. Any ideas, or tricks to doing this? Please help
Old Sep 20, 2002 | 08:21 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
OK, A couple of quick ideas - You might remove the bolts you have in now and try starting the back ones first, that way at least maybe you can see what you're doing a little better. Or, you might try starting the center bolts first and working out from there. That's the best I can do off the top of my head. Good Luck.
Old Sep 22, 2002 | 03:08 PM
89Irocz23's Avatar
I agree thats what I did when I replaced mine
Old Sep 24, 2002 | 03:28 PM
racereddy20's Avatar
Ditto here. I was trying to get away with the first three up front and ended up doing this.
Old Sep 24, 2002 | 11:15 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
When I put mine in I put one of the center bolts in to hold it up and then went back to front.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
MY87LT
Aug 17, 2015 08:43 AM
mdtoren
Aug 16, 2015 05:45 PM
