getting coated edelbrock headers with y-pipe from Jegs
Old Sep 25, 2000 | 10:09 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
What do you guys think of those headers? Are they any good? I want to get them because they come ready with a y-pipe. And here is the hard question: What is the difference between the rs version ones and the tpi or z-28 version ones? If its just the end size of the y-pipe (bigger for the tpi or the z-28's cause they came with bigger cats) than i definitely want to get the bigger one. Is that the only difference? Has anyone installed these headers on their car and if so was it a PITA? Thanks for any comments or suggestions, i plan on doing the work myself.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Sep 25, 2000 | 11:01 AM
Cowboy's Avatar
The only difference is the Y-pipe and some of the mounting hardware maybe. I got my TES over a year ago and love it. I bought it uncoated and spent some time cleaning up all the casting flash and grinding down the air tubes that stick into the inlets. Then I sent it to Jet-Hot coating for an in and out job and they look as good as new today. I've seen cheaper coating peel off on the first startup so be careful. As for the install, it was a PITA but do-able. Read through the archives here for some good tips on how to do it.
Old Sep 25, 2000 | 06:20 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I thought the installation was fairly easy. If you've never done it before you might not think so. The system I have is Edelbrock part #6872, the y-pipe is made up of two 2.5" pipes that end in a 3" collector.
Old Sep 25, 2000 | 11:37 PM
Abe91Z28's Avatar
jed, i have the same headers! but i was worried about them because the package says that they are for 87-90 Irocs and Z28 350-305 and i have a 91 Z28, but i haven't installed them yet, im waiting untill i get more money and buy the cat and the cat-back and me and some buds are going to do it all in a weekend (hopefully it won't take longer then that) But, as for now i'm having a hard time on finding a nice cat and cat-back to go with this system. Any suggestions? ANYONE?
oh, and i almost put the TES in my self b4 i got the cat and CB, i had most of the passengers side off.. not too hard and that is the hardest looking side (because of AC)
Well, enough babbling
-Abe
Old Sep 26, 2000 | 12:03 AM
Car: 88 IROC
Transmission: auto
I would go with the hooker cat back system. You can get it from jegs. Suppossedly the aerochamber muffler makes slightly more torque than straight open pipes. I got it and its great.
Old Sep 26, 2000 | 12:13 AM
Abe91Z28's Avatar
yea, i really like what i'm hearing about the hooker system, i also wanted somthing different because my friend has the flowmaster on his car but, i'm wondering if i should try to go 3' back? Or, is it OK to have the headers outlet at 3' and then get a 2.5' cat and CB?
Opnions wanted!
-Abe
Oh, BTW one more question, should i heat wrap my TES once they are in? and if so what heat wrap should i use? I'm looking at this stuff by thermo-tec, but i really am kinda clueless on this. Any help would be great!
Thx again!
-Abe
[This message has been edited by Abe91Z28 (edited September 25, 2000).]
Old Sep 26, 2000 | 12:30 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the TES and they were a breeze to put in. Easily a 1 man job. If you need instrutions just ask. I have that going into a 3in Catco then going into a 3in Edelbrock catback and i LOVE IT
Old Sep 26, 2000 | 12:31 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
About the header wrap. I know a guy on this board that had that done and some oil leaked on to the wrapping and when they fired the car up it caught on fire. Luckly they put it out in time.
Old Sep 26, 2000 | 12:35 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
If you're getting coated headers then why are you wanting to put header wrap on them?
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Sep 26, 2000 | 08:33 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Abe an anyone else trying to choose exhaust pieces,
I'm gonna share my exhaust experiences with you guys because I ended up buying two seperate exhaust systems over the course of a couple of years. If you get the right pieces the first time maybe you won't have to.
System #1 - done by exhaust shop. Edelbrock headers #6876, factory dual-cat y-pipe (gutted cats) 2 7/8" pipe to Flowmaser 2 chamber muffler.
Problems with this system:
1) Got sick of the Flowmaster sound
2) Gutted cats can be noisy
3) In order to pass emissions my exhaust shop removed a section of the 2 7/8" pipe and installed a cat. After the test the removed the cat and installed a 2.5" pipe.
RESTRICTIVE!
Your exhaust system will only flow as much as the smallest section of pipe will allow!
System #2 - done by me! Same Edelbrock headers but with y-pipe from #6872, 3" Hooker Aerochamber cat-back, Hedman 17164 exhaust tips.
This system is way louder than the Flowmaster system, and sounds deeper. The performance difference between 2.5" and 3" is BIG. Go 3" all the way from the y-pipe.
The factory y-pipes all suck, even the dual-cat pipe. It necks down to 2" in several places. The Edelbrock y-pipe maintains two 2.5" pipes all the way to the 3" collector.
Just what I picked up on while going through all this. Do it right the first time.
Old Sep 27, 2000 | 08:53 AM
Car: 88 IROC
Transmission: auto
What about the slp y-pipe? I think i'm gonna get the slp headers (1-5/8) because they are on sale on special right now and i won't have to get them coated cause they are stainless steel.
Old Sep 27, 2000 | 10:21 PM
Abe91Z28's Avatar
Jed,
your second time sounds awsome i was really thinking of a hooker catback, but on your 2nd time where was your cat?!? :P just messend with ya, i was thinking of running catless, but then i'll never pass emissions up here in WI. So, i'm wondering where could i get a nice 3 inch hi-flo cat for our cars? any suggestions? I'm kinda on a 400$ budget here and i've found the cat-back for roughly 250$ so, i have around 150$ ish to spend on a cat (i can go over 400 i just don't really want to
Thx!
-Abe
Old Sep 28, 2000 | 08:24 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
According to everything I've read the SLP headers & y-pipes are a little better than the Edelbrock stuff, but damn...those prices.
Jegs http://www.jegs.com sells Dynomax high flow converters. Last I looked the 3" cat was a little under $150.
Personally, I don't care for cats. I'm more of a dog person.
[This message has been edited by Jed (edited September 28, 2000).]
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
