Header Wrap Questions
Old Oct 21, 2002 | 08:40 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I was looking in the Summit Catalog today, and I noticed DEI header wraps say NOTE: Wrap voids most header maker's warranties. Why is this? Does the wrap damage the header?
Old Oct 21, 2002 | 09:08 PM
80 Camaro 355's Avatar
Car: 1980 Camaro Berlinetta
Engine: soon to be 383
Transmission: TH-350
Axle/Gears: GM 10 bolt 8.5 3.23
They tend to rust out the primaries due to moister build up.What you need to get are the header jackets...those will keep your plug wires from being burnt up and keep things cool.
~Nathan~
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Yes, over time the heat retained in the headers because of the wrap will literally break down the metal. This is one of the reasons why the better ceramic coating companies coat inside as well as outside.
Old Oct 21, 2002 | 09:13 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Will the jackets rust out the primaries as well?
Old Oct 21, 2002 | 10:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
bad idea.
Most likely you would have to really be a professional to do it right.
It can trap moisture and speed up rusting. and it's a fire hazard, if any oil leaks on it. cars have caught fire before from it.
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
