Anyone with Mufflex 4in in/dual 3's out?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I don't have that exact setup, I'm only missing 1 pipe, but the system is loud. If your looking for a throaty sound and a deep rumble, this setup is it. Sorry, no sound clips.
One thing that I've been telling everybody since I put mine on is to not use Mufflex's hangers. The system will sit too low. If you can weld or know a good exhaust shop, have them put it on with custom hangers. Also, they may need to cut some of the pipe so it will sit closer when it goes over the axle. I've got mine stuff up in the car so tight that you can't even tell there's 4 inches of sewer tube under the car.
Hope that helps.
Hope that helps.
Car: 99 Formula
Axle/Gears: 342
Hope that helps.
Hope that helps.
Car: 1991 Z-28
Getting it out of the way. I have bigger plans in the works right now and I don't want to have to worry about an exhaust later down the road.
Terrell351
Jun 13, 2021 01:13 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
