I need help getting my Edelbock Header On
Old Nov 15, 2000 | 01:00 PM
1989CamaroRs's Avatar
Im installing TES headers on my car, the driver side went on very easy, but ive been screwing with the passenger side now for hours and gotten nothing done. Can someone give me some instruction
[This message has been edited by 1989CamaroRs (edited November 15, 2000).]
Old Nov 15, 2000 | 01:09 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
Well which driver side are you having trouble with.... driver driver side or the passenger drivers side. well which drivers side is it. LOL
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 super comp long tubes, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Nov 15, 2000 | 01:12 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Hmmmm, sounds like you have 2 driver's side headers. Seriously, if it's the pass. side, you might want to do a couple things before trying to install the header. Drill out the mounting flange bolt holes so that you have a little wiggle room. Tap out all of the header-bolt threads in the heads, especially the last one (or is it the second to last one?) on that side since the stock exhaust manifolds didn't use it and it's probably got some crud in it. This should help get the headers bolted up.
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 15, 2000 | 01:14 PM
opps i ment to say the passenger side as in the one with the damn ac in the way, guess i should edit that out, also should i be putting the header in with the flange side going in first or with the the frontside first
Old Nov 15, 2000 | 01:32 PM
Car: 90 Camaro RS
Engine: 305 TBI
i have heard...pass side goes in from top,
drivers side from bottom...or was it the other way around. well try doing the opposite of what you did for hte driver side. good luck
Old Nov 15, 2000 | 02:30 PM
thanks guys i got it in, now im having a great time trying to put my dipstick back
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
