Yet another dual exhaust Idea (this may acutally work)
Old Nov 10, 2000 | 06:23 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I was thinking of running dual pipes along either side of the driveshaft tunnel, then the pass side one would run over the axle in the stock location, and the drvs side one would run over the axle in between the panard rod assembly. Both pipes would dump into mufflers on either side of the gas tank (similar to a vette). What do you guys think?...if it would not work please state why.
Old Nov 10, 2000 | 08:33 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Bowtiroc,
This would work. I saw a picture of this exact setup in a magazine once. It was a very very nice setup, professionally done in stainless steel.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Nov 10, 2000 | 09:00 PM
Marc 85Z28's Avatar
If you removed the torque arm and relocated the panhard bar and brace, then it might work.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Nov 10, 2000 | 09:35 PM
82z's Avatar
82z
I really don't think that you could run a pipe between the axle and panhard rod and stay away from the gas tank. My exhaust runs under the passenger side and out the back. It looks pretty professional but the pipes are crush bent. I'll sell it to you when I take it off.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
Old Nov 13, 2000 | 08:19 AM
Kenn's Avatar
I've seen it done on fourth gens - I think Grottingham or Grottington (something like that) makes a kit - But I think the Panhard and/or Panhard bracket support rods are modified for clearance-
I think it could work with modifing the Panhard rod or the Panhard support rod maybe not necessarily both - I ran duals similar but I removed the Panhard bracket support rod altogether - there is only 9in width on both sides of the tank so muffler selection is kinda limited- definitly doable though
Old Nov 13, 2000 | 11:25 AM
Pino91Formula's Avatar
I still dont understand why everyone is set on putting true dual exchaust on there , car, as long as you put a good aftermarket setup on , you'll flow just as good if not better then trying to plum true duals , these cars were just not designed for that setup.
Old Nov 15, 2000 | 01:35 AM
BOWTIROC's Avatar
Pino, I understand what you are saying and I totally agree if the dual exhaust is not needed. I am running roughly 500hp and when talking to several different muffler companies, they said I would need either single 4.5-5in or dual 3in. Since no one offers this single setup I am forced to make my own. I know that mufflex advertises that their 4in system is good to 550hp, but that is not what the muffler manufacturers say.
Black 89 IROC...Mods: 355, 11:1 comp, Big Solid Cam, Ported TFS heads, Victor Jr, Holley, and a 5 spd...yes, it is fun
Old Nov 15, 2000 | 03:29 PM
Mo's Avatar
Mo
What about flexible exhaust tubing? you can get a 25 foot roll of 3" premium grade SS for under $200
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
