Hooker cat back installation?
Old Nov 10, 2000 | 11:48 AM
Casey'91Z28's Avatar
I'm putting on my catback today one way or another, either by myself or having an exhaust shop do it. My question is on the instructions it says that the car has to be raised 36 inches to install it, I have four jackstands will that be good enough? Or would I be better off having someone do it for me? How much would I probably pay?
'91 Z28 305, Auto trans, K&N filters, power pulleys, ported plenum, hypertech chip, dynomax cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Nov 10, 2000 | 03:32 PM
I had an exhaust shop do it for $90 bucks so that I didn't have to deal with it. It sounds awesome, I highly recomned it. The dual tips look sweet.
Old Nov 10, 2000 | 04:21 PM
rich1034's Avatar
I did mine myself, and only used 2 cheap jackstands from WalMart, and it wasn't too hard at all, with the split intermediate pipe, it doesn't really have to be raised that much.
Old Nov 12, 2000 | 06:38 PM
Keith5's Avatar
Car: C1500
I'm waiting on my Hooker Cat Back right now. I got my old one off today. All I used was two homemade ramps that my dad made a long time ago, they aren't that high at all, maybe 7 inches. I got the old one off alright. I drove the back wheels up on the ramp. I might have to use some bigger ramps or my jackstand when I put the system on but I doubt it.
1989 Pontiac Firebird Formula W6S LO3 TBI 305.
1985 Camaro IROC-Z LB9.
Old Nov 28, 2000 | 08:36 PM
Keith5's Avatar
Car: C1500
I got it on today, it took about a week on and off because it got cold, today was the first semi-warm day I've had to work on it. I used the little ramps. Hangers and outside conditions were my greatest enemy in the installation.
-180 degree stat
-Hooker Cat-Back
Old Nov 29, 2000 | 02:28 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
did ja have to weld anything??
Old Nov 29, 2000 | 04:47 PM
Dan87IROC-Z's Avatar
I've put on 2 Hooker Cat-Backs this past summer, both were easy as 1,2,3. No welding is needed, just a floor jack and maybe some stands (even though I didn't use them). The only problem is the intermediate pipe rests on the part of the rear suspension because the hangers are a little messed up.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Nov 30, 2000 | 12:04 AM
hemdawg's Avatar
dan87iroc doesnt know what hes talkin about. one of the two he mentioned he put on was help with mine it wasnt as easy as one two three. his may have been, but mine wasnt. first the bolts were so rusted we had to cut the intermediate pipe in half. then for some reason the pipe going over the axle didnt quite clear it so when i drove it you could hear the pipe bang a lot. on top of that it was crooked and i couldnt get it straight. the banging also caused it to twice come totally disconnected from the intermediate while driving. after that i had a muffler place weld the sonsabitches together. now it doesnt bang and its straight.
Old Dec 1, 2000 | 10:48 PM
Keith5's Avatar
Car: C1500
I wouldn't say that the installation is as easy as one two three, but I wouldn't say it all that hard either. I had to use a universal hanger on the passenger side. I don't have any noise of banging from it. Mine has plenty of clearance over the axle, but it does touch part of the suspension, the panhard bar, I don't think that the part it touches moves, or if it does it can't move much because I haven't heard a thing. It is hard to get the stupid thing to line up right. Once I got it all together, it wasn't straight or in the right place. I had to take a rubber hammer and persuade the tailpipes to go where they are supposed to go. Even then after I was finished and put the tips on I found that the driver's side pipe isn't exactly parallel with he car. One of my friend told me how to correct this today, take the tip off put a piece of wood in and pull it straight, it is that far off so it shouldn't crimp the pipe or anything like that.
-180 degree stat
-Hooker Cat-Back
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
