best gaskets for TES headers/
Old Dec 9, 2000 | 08:48 PM
88IROCARMY's Avatar
I got the TES headers for my 88 IROC, they are used and without a gasket. What is the best gasket that you guys have used. One that dosen't blow after a week, I'm willing to spend the money for a good one.
Some examples
MR Gasket copper
Flowtech multi layer dead soft aluminum
Or your suggesstions.
Also a square port or square, the ports on the headers aren't actually very square. 1.5 or 1.45. Thanks
Old Dec 9, 2000 | 10:33 PM
Dan87IROC-Z's Avatar
I have heard nothing but good about copper gaskets. I have had good experience with gaskets from Fel-Pro.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 9, 2000 | 11:25 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've got some of those aluminum ones, and they work great. They cost like $30 though. Kinda pricey, but worth it. I went through two sets of Mr Gasket paper gaskets before I wised up and got the aluminum ones. And they're reusable. If you want to be extra careful you can get those stage 8 locking header bolts too. I haven't needed them with the aluminum gaskets, but with the paper gaskets, I actually had a bolt fall out!
Old Dec 10, 2000 | 10:03 AM
88IROCARMY's Avatar
I'm pointing myself towards the aluminum ones the price is $30, really not that bad. I took the TES to the store and held them to the gasket the gasket ports seemed a little to big. The openings were 1.5 square. But they should fill everything in once compressed. Also any suggestions when installing those headers. Thanks
Old Dec 10, 2000 | 03:31 PM
Tom Keliher's Avatar
My original Edelbrock supplied gasket blew out after a few months. I bought a standard FelPro "blue" exhaust gasket and it has been in for a few months and so far no problem.
Old Dec 10, 2000 | 06:59 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have a set of the Felpro 1404s they have worked well for me. IM using Felpro thru out my new motor. The quality is much better than stock replacement.
I had the same problem with the supplied gaskets. That passenger side header is a bitch IM not looking forward to doing that again.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Dec 10, 2000 | 10:38 PM
My TES gaskets have lasted a year, and my friend's on his 88 IROC have lasted 2 years.
L98 TPI 350 (5.7L)
Old Dec 11, 2000 | 09:16 AM
pete92rs's Avatar
I have Mr. Gasket copper header gaskets on my car for the past 8 months. So far no problems.
Old Dec 11, 2000 | 04:58 PM
88IROCARMY's Avatar
THANK YOU
for all the replies.
Please share with me your experiences while installing the headers.
Like tools, problems and general advice.
The car is an 88 IROC 305 TPI serpentine setup. Also how you guys coated your headers. Thanks
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
