My Dual Exhaust idea... what you think???
Old Dec 13, 2000 | 01:38 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Guys here it is:
'91 GTA w/ L98/5-spd. ZZ4 cam and edelbrock headers/y-pipe + other mods. I thought about taking my cat off, then where the ypipe is still 2 pipes(right before the cat) cut it off and have someone run duals to the back and over the axle. Then I was thinking about running some 1 or 2 chamber 2.5" Flows under each back ground effect. Understand what I mean. I've seen it done on a 3rd gen drag car and I think it would maybe work? Any thoughts? The mufflers would be right at the back of the car... any problems with this. They would be sitting perpendicular to the axle. I think you could turn the mufflers at like a 45 degree angle like they do on 4x4's(still perpendicular to axle though). By perpendicular I mean that the flow(entrance/exit) pipes would be perpendicular to the axle. Know what I mean? Or just confusing? In other words, they'd be sitting just the opposite of a crossflow, but at the two corners back there and turned about 45 degrees from horizontal, wedged in there(not too close though)It looks like there is sufficient room. Let me know what you all think. THANKS!
'91 GTA:5.0-5-spd, chip, K&N,Flows,Coil,Air Foil, 350 soon to come!
'39 Chevy coupe
'52 Chevy p/u
Old Dec 13, 2000 | 06:14 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
where were you planning on running the pipe and what diameter. ive seen the newer caddys and there mufflers are similar to what is described. at 45* angles to bumper and rear axle. then a short bend straitens out the tail pipes. it could work depending on how big the mufflers are...i dont have a 40 series lyin around LOL....but it would require a pro. for a good exhuast you always want mandrel bent tubes not the ones with folds on the inside of the bend. this would be a custom job as noone makes this premade....so if you have the money try it out. good luck. rIck
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 5/8 shorties, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo on the way)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Dec 13, 2000 | 09:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is only 7 to 8 inches of space between the trunk well & the spare tire well and not alot better on the other side, 32" from the panhard brace to the lip of the bumper, and 2" of depth from the lip of the bumper to the frame & about 6" nearer the panhard brace. I was thinking of doing similar with pacesetter corvette mufflers until I called for dimentions and found out basically,, no way will they fit and look right. The only mufflers (if you want to call them that) are the dynomax bullet(round) mufflers,, and I still don't think that would look right. also I'm not to sure how well 2- 2½" pipes will squeeze thru where the factory pipe runs,, but there isn't alot of room. Maybe at the point there you could 'Y' the exhaust into a single short 3½" straight piece to fit thru and then 'Y' it back into duals. I still think the muffler fit would be iffy though.
Da Boid
- 4 out of 5 people think the 5th is an idiot
Old Dec 13, 2000 | 09:35 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I still don't think you understand what I mean. I want to run the mufflers parallel w/ the frame or perpendicular to the axle. In other words... turn the crossflow 90 degrees. Then when they are sitting in this position turn them 45 degrees from horizontal. I think there would be enough room, and I know I've seen it done on a drag 3rd gen for the track. It was streetable though... NOT TUBBED. WEll, I'm open to more comments if ya got 'em. Thanks
Old Dec 13, 2000 | 10:38 PM
deadbird's Avatar
Engine: TPI 305/ v6
I guess I'm the 5th person in my sig but,, you wanting it to look like vette exhaust only the mufflers are twisted at 45° (as if laying on the ground looking str8 at them) or at a 45° angle in relation to the rear end itself (not parallel like a cross flow and not 90'd like a vette)? I'm guessing you mean the 1st but,, either way,, the trunk well takes up any room you have under there. maybe the drag ar you saw had the lower half of the cut off so they could fit exhaust ? (I'm trying lol )
Old Dec 14, 2000 | 12:28 AM
MrJ's Avatar
MrJ
Do you plan to run an H pipe? Be forwarned that true duals with no H or X pipe between the two pipes doesn't sound too great.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
Old Dec 14, 2000 | 01:59 AM
gsmann's Avatar
I have a true dual setup with no h-pipe. it sounds pretty darn good. it depends on your test. i like the exhaust choppy. i might get an h-pipe to see if there's a performance difference but i like the sound with no h-pipe.
Old Dec 14, 2000 | 03:35 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I guess you'd say it would be like a Vette's system except that the mufflers would be turned at a 45 degree angle when looking form straight behind. Instead of sitting flat like normal, they'd be sitting ****eyed from horizontal. This means they would be kind of wedged in there. When you look at the horizon (like the sun setting over the water) take the water level and turn it 45 degrees. This would also be like looking at the car from behind and turning your head at a 45 to the side from straight up. Actually looking from straight behind at the bumper it would look like this: / instead of a normal muffler looking like this: - on the vettes. You know what I mean now? Later, hope this helps.
BTW- I'd plan on using a H or X pipe too!
'91 GTA:5.0TPI-5-spd, Hypertech Stage 2 chip, 160stat,!TB,!Cat, K&N, Flowmaster muffler, Accel Coil,TPI Air Foil, 1LE Alum DS, poly-tranny mount, KYB's all around, & a Hotchkis Strut tower brace.
Mods in progress:
-L98 w/ZZ4 cam/springs
-Edelbrock headers
-3" flow setup
Future:
-T56/heavier clutch
-Hurst or Ripper
-4.10's
-Ram Air II Hood
-1.5" Springs
-Rebuild suspension!
Others:
-39 Chevy coupe
350/350/3.55posi
-52 Chevy p/u
-77 Bonneville 400PONTIAC/400turbo/posi
Original 50k mile 2 door... Gramp's old car!
*** Gotta love those Poncho's***
[This message has been edited by GTA91 (edited December 14, 2000).]
Old Dec 14, 2000 | 03:42 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
DEADBIRD-
I read your post again and I think you kow what I mean. Vette's twisted at a 45! THX! Think it will work?
Old Dec 14, 2000 | 05:53 PM
deadbird's Avatar
Engine: TPI 305/ v6
GTA91
I was having the same idea of putting a vette system on mine, even if it wasn't true dual but just to have the 2 mufflers at the back the way a vette does, the problem I found is that there just isn't alot of room at the back bumper (measurements in my 1st post). If there were a muffler that was no wider than 7" and 4" in height, this would work because the space where they would have to go is only 8" wide.(between the deep recess of the trunk where everyone like to put sub-boxes)& the spare tire well) If you are looking at the back bumper, from the bottom lip of the bumper to the frame rail on the underside, the depth to tuck a muffler up there is only 2" deep. That's why I was saying something like the dynomax round muffler would be more suited to this application, but I don't think they would be quiet enough (unless you want loud).
I made a temp. straight thru muffler packed with fiberglass for my bird (until I can decide on exhaust and get motor working right) welded up where my cat was and about 1.5' of 3" pipe off of it and I can say it is very deep & quiet idling,,, but loud on the gas. Dynomax claims for 'high horse street...' so I don't know if they would be quiet or not. if it's like what I made,, I do like the very deep tone,, but the rest is too much,, of course I am sitting on top of the outlet basically. Hopefully the first half of this makes some sense. I guess to sum it,, it would be a h-ll of a trick to get something like flowmasters back there w/o some modifying the surrounding metal(of the trunk) or going the route of round mufflers.
Old Dec 15, 2000 | 01:38 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I've seen it done th exact way you are saying, w/ the dynomax bullets. It looks andsounds great. There is plenty of room and it is easy to do. I'm notso sure how well the pipes clear the where the intermediate pipe was, but I'm pretty sure you could make it fit. I'm considering doing it soon also
Justin 87 GTA--organizer: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
Old Dec 15, 2000 | 03:11 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thats cool! Where can I get those bullets? How much? THX!!
Old Dec 15, 2000 | 04:08 PM
deadbird's Avatar
Engine: TPI 305/ v6
I think JEGs and Summit both carry them in 4,5, & 6" round cases ranging from $35-$70 a pop (depending on size).
Old Dec 15, 2000 | 10:43 PM
Basett Racing's Avatar
[This message has been edited by Basett Racing (edited December 15, 2000).]
Old Dec 15, 2000 | 10:49 PM
I used to have a pretty unique dual setup on my 82 Z, it consisted of Hedman shortys, and 2.5" pipe using 2.5"ID X 36" long Dynomax Turbo Tubes. The exhaust ran down from the headers, and turned out about 8" the turned back vertically. I had the Turbo Tubes mounted in the "trough" between the floorpan and where the rocker panels are pinch welded. They are have a 3"OD and fit perfectly into the "trough". After the muffler, they ran about another foot then turned down slightly. The car was pretty mellow in idling/normal driving situations, but they really howled under accelleration. Before I ever heard this set-up, i was afraid it would have the ragged, 70's Ford truck, poppy "cherry bomb" glasspack sound, but it was not at all poppy and it sounded wicked!
I painted the whole exhaust system w/ VHT flat black header paint. It had better ground clearance that the factory exhaust due to them being tucked under the car in the "troughs". If you have a car w/ ground FX, e.g. Z28,IROC, RS, the exhaust isn't even visible, but when I painted my car, I took off the ground FX, and you could see the exhaust. It was a pretty clean set-up, but now I have upgraded to 3" all the way back to one-chamber Flowmasters, since the car only sees limited street use. I am planning this setup my 89 RS. Just another suggestion.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock http://www.bassettracing.cz28.com
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
