THAT F*CKING CACKLE/POPPING NOISE
Anybody else have this problem? I have a glasspack welded in place of the cat, and it rattles like a SOB, so I'm replacing it anyway, I was thinking of replacing it with a chambered exhaust piece.
Basically, I have stock manifolds, that stupid glasspack in place of the cat (no, I didn't put it there), then 3" pipe all the way to the back where it Y's off into a dual-look with dual monza tips on each side (looks good), there is no muffler (other than the aforementioned glasscrap...er..pack). Will putting the chambered exhaust piece in place of the glasspack help the cackling from my exhaust any? I love the tone I have, but it sucks to put on a show that spectacular, only to decellerate and end it with -cackle-cackle-POP-pop-pop-pop-.
Any suggestions?
KElly
[This message has been edited by IROCracer (edited December 11, 2000).]
Any suggestions?
KElly
Yeap, I had two glasspacks there and one broke inside then the other, I think it was because of the heat. Try replacing it with a cat then put a small round muffler, found in Jegs, on each side where the exhaust comes out at the end of the car. This will be on each side of the gas tank. This is basically what I have and the sound is just great.
Hope it helps!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Hope it helps!
89 IROC 350 Auto
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
hmmmmmm...sounds like an idea. Your car doesn't pop or cackle when you decellerate?
I wish I had some idea of what your car sounded like. I love my tone (other than the rattle of the broken glasspack and the popping and cackling). I swear I can wake the dead, but it's not that annoying open exhaust sound. Dunno.
If you've gotta fix it, fix it better than stock.
Car: 90 Camaro RS
Engine: 305 TBI
its cuz you have no cat....put a hi flow cat in....and 40 series muffler in the back. if the pipes are 3 inches then just get the muffler...if not....then i would suggest a cat back system...replacing all the pipage from the cat back.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 5/8 shorties, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo on the way)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Rick
It is not because he has no cat, it is because there is not enough back pressure to keep it from doing that. It is true that alot of cars do that when they remove the cat but not all do. We have the Headman shorty headers 2.5" pipe of of the headers into a 3.5" Ypipe into a 3" M.A.C. offroad pipe and 3" M.A.C. cat back system with 2.5 dule outlet pipes and 3" tips with resinators in them and this car does not breath back when she decelerates. To cure your problem you will need to put some sort of muffler on it at the very least. I think the exhaust with the round mufflers just before the tips would sound like an old dule exhaust car (or just about any older truck) with glass pacs, which is not a pleasant sound at all. In my opinion anything with glass pacs (that the owner put on intentionaly thinking they are a good thing) just screems HOOPTY!!!!! You might want to just get a good cat back system. This would solve your problem and depending on the system would still sound real good.
Man, what is wrong with you? That "f*cking" noise is the sound of a high-performance engine...EVERY car that hasn't been restricted to death to satisfy enviro-***** does that on deceleration. If it annoys you, bump the shifter into neutral. Sheesh.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah...all cars will do that. i've seen it on a million cars.
i guess from what i have learned, is is from a lack of back pressure...but who cares? a lack of back pressure is usually a good thing, and a lot of people like teh sound.
i woudl ditch the glasspack idea, get some pipe and replace the cat with that. then get a 40 series flowmaster. they will give you a MEAN sound that is probly a little cleaner than the one you get with your current setup.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Brian's 1991 RS
M.A.C. sells an "off road" pipe that replaces the cat. It is a 3" pipe that just bolts in to where the cat is now. If you get that and a good 3" cat back system you should have no problems.
82 Z28 with 350.motor has .030 forged flat top pistions other wise stock bottom end, Summit 214/224 cam with 1.6 Harland Sharp roller rockers, stock 882 heads for now (will be getting a set of the 23 degree Trick Flows this summer), Performer RPM intake, Holley 750 Vacuum secondary, Th350 with 2200 converter, stock 3.23 geared rearend for now (getting 9" later on), Headman shorty headers, custom 2.5" into 3.5" Y pipe into M.A.C. offroad pipe and M.A.C. cat back system. So far car has only been to the track twice and is having sever traction problems but is running 60'-2.34 1/8 mile-9.2 @ 79 MPH.
sjorgens
Oct 1, 2015 07:54 PM
