Is 1 1/2 primaries too small for my car?
Old Dec 21, 2000 | 05:37 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Are these headers too small for my mods? I will be porting my heads soon.
What do you guys think?
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Other things coming soon: Fully Ported Head, New valves, 1.6 rockers, Relocation of MAT sensor, Better quality clutch.
Old Dec 21, 2000 | 08:21 PM
Dan87IROC-Z's Avatar
I would definetly go larger that 1 1/2" inch, for your mods on the 305, I would go with the 1 5/8" for sure. 1 3/4" work best with the 350s, I wish I would have gotten 1 5/8".
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 21, 2000 | 09:22 PM
Jester's Avatar
1.5" headers are the best match for a vast majority of 305's. You'd have to be solidly over 300hp before you need to step up to 1 5/8"..and thats very hard to do with a 305.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
