Cat Back 3" Exhaust Kits - Feedback
Old Nov 13, 2002 | 06:02 PM
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
lOOKING FOR FEEDBACK FROM ANYONE WHO'S INSTALLED ONE OF THE CAT BACK 3" EXHAUST KITS.
DID IT MAKE A NOTICABLE DIFF IN POWER?
BRANDS AND PRICES YOU'D RECOMMEND?
GIFF
Old Nov 13, 2002 | 06:04 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
what are you putting it on? mods?
I'm happy with my Hooker cat-back $200, needed minor fab work, or a $260 bolt on.
Sound clip in sig.
Most aftermarket cat-backs will be the same HP output wise on a near stock motor.
click the pic in my sig too.
Old Nov 13, 2002 | 07:00 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
i have the edelbrock 3 in system. very happy with it. power gains were very noticable, though i did put the whole exhaust on at once.....
Old Nov 13, 2002 | 08:42 PM
giff's Avatar
RIGHT NOW IT ONLY HAS A 180 DEGREE THERMOSTAT AND A K&N AIR FILTER. SO LOTS OF THINGS THAT CAN BE DONE...
I'D LIKE TO START WITH 3" CAT BACK EXHAUST, MAYBE A LARGER THROTTLE BODY - LET IT BREATH A LITTLE...
LATER ON MAYBE STAINLESS HEADERS AND SOME INTAKE RUNNERS, HOTTER IGNITION SYSTEM.
I THINK WITH A BIT OF TWEAKING AND LETTING THIS THING BREATH I CAN MAKE A NOTICABLE IMPROVEMENT WITHOUT OPENING UP THE MOTOR. NOT INTERESTED IN DUMPING A BUNCH OF MONEY INTO A THEN TEMPERMENTAL BEAST. (LEARNED MY LESSON IN HIGH SCHOOL...)
MID TO LOW 14'S ???? I THINK THAT WOULD BE REALISTIC. THROW IN THE MINOR SUSPENSION MODS - STB, SFB, STEERING BOX BRACE, SHOCKS AND I'LL HAVE A SOLID LONG LASTING RIDE.
GIFF
Old Nov 14, 2002 | 07:50 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Mid to low 14's on what type of engine?
Old Nov 14, 2002 | 03:49 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Giff - for the money you seem intent to waste on a larger throttle body even tho all the TPI guys told you don't, you can make a cold air setup, upgrade ignition, and get a throttle body foil! Why do you want to spend 300 dollars or more to see marginal power losses from a larger TB?!?!
Dude you're young like me and I understand not having enough cash to do major stuff to your car... however, for the hundreds spent on a larger throttle body you can port/polish the living hell out of your plenum and base - now that's actual power gains.
Old Nov 14, 2002 | 04:00 PM
Car: 99 Formula
Axle/Gears: 342
Mid 14s on an LB9 w/o G92 option, will need some gears and a higher stall TC with full exhaust at least.
Old Nov 14, 2002 | 06:51 PM
giff's Avatar
"Intent on wasting money"...nah!...hardly.. that's why I'm on this forumn!
for the approx 12 years i've had my formula i've heard/read about many supposed "fixes" for easy horsepower.
i'm intent on only one thing - soliciting enough feedback from various sources and then mixing in a little experience and some good old gut feel - been around longer than you may think - to come up with a good package. IE the best mix of cost/power/drivibility/longevity.
giff
91 formula, 305 tpi, 5 speed, 3.42 limited slip, diff, twin cat exhaust
Old Nov 14, 2002 | 07:03 PM
Car: 99 Formula
Axle/Gears: 342
giff
Wait, 305 5 spd, 3:42s, sounds like a G92 car, dude you should be real close if not at mid 14s if you're a good driver.
Old Nov 14, 2002 | 07:16 PM
giff's Avatar
Decent driver I guess...but i've riddin in cars i KNOW are mid to low 14's and mine ain't that fast. having never run it on a qtr mile i'm guessing upper 14's??? to low 15's??? according to all the literature i've got (motor trend artical on the "new" 91 formula and varuous articles from the day) out of the box that's about all they'd do.
lots a potential though
giff
Old Nov 14, 2002 | 07:20 PM
Car: 99 Formula
Axle/Gears: 342
Nah, there a few members on here I believe with near stock ones that run 14.2 or so.
Old Nov 15, 2002 | 02:33 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
a 14.2 with a stock 5.0 TPI? I'd expect this is at Sea Level or damn close.
& giff i apologize. =\
Old Nov 15, 2002 | 07:23 PM
giff's Avatar
A stock formula like mine running 14.2 ? That's STRONG. I'd be very curious to hear from anyone who's running these kind of numbers.
Enlighten me, seriously, as to what your doing to squeeze that kind of grunt out of your ride.
giff
Old Nov 16, 2002 | 01:00 AM
Car: 99 Formula
Axle/Gears: 342
I never said stock, I meant near stock, like full exhaust and maybe a little tpi work.
Old Nov 16, 2002 | 07:41 PM
giff's Avatar
On the topic of "full exhaust" - I'm assuming you mean headers and 3" exhaust?
How hard is it to install headers on a 3rd gen f-body and do you have any problems with excessive heat frying starters etc?
Had headers on a 66 Lemans I had years ago and when hot it could be a pain to start.
Thought about wrapping headers in some of the "tape" that's sold to reduce the underhood heat. Can't think of what they call it...
giff
Old Nov 17, 2002 | 12:21 AM
Benny's Avatar
I installed the SLP #31007 for my application, it is 3" with dual 21/2" tips that exit out of the drivers side, it did make a noticeable difference that I could notice since I have no other mods. Pricy at $399.00, but it is all stainless steel.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta power
Aug 13, 2015 06:15 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
