Which headers? 1 3/4 Hooker LT or SLP 1 3/4
Old Jan 16, 2001 | 12:51 PM
NOSFEDGTA's Avatar
Any help would be great. They will be going on a 383cid with afr heads and Super Ram
Old Jan 16, 2001 | 10:34 PM
Dan87IROC-Z's Avatar
From what I have heard, the SLPs 1 3/4" are the best you can buy. So, if you have the money, go for those!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 17, 2001 | 02:44 AM
Gta-Paladin's Avatar
They are long tubes though... I am yet to find anyone willing to tell me if they bottom out with them or not...
Old Jan 17, 2001 | 04:40 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
SLPs are the best SHORTIES money can buy. Hooker LTs will get you max perf. but will cost a pretty penny. cuz you also need to buy a y-pipe from mufflex(Bout 250) or have one custom made. also keep in mind LTs will not pass visual inspection. might pass sniffer. good luck. i havent heard any trouble with ground clearance...just b careful...mine are on the waay.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Jan 18, 2001 | 09:47 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I'm using the SLP 1 3/4 right now but will be DITCHING them for a set of Hooker long tubes. Reason!! The Slp's DO NOT work with angle plug heads, i had to ding/pound the last 2 tubes on both sides to clear the plugs, but it still is close enough to be melting my wires, and i'm using some slip on wire shields also. That's my 2 cents
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
all runs made on BFG Radials (NOT DRAG)
Complete Steve Spohn Rear Suspension
Full Custom Dash full of Autometer guages
Extremely Loud Stereo !
Driven Daily
Old Jan 18, 2001 | 10:06 PM
CamaroMike's Avatar
Slush, tell me more about which heads you have and why the headers did not fit! I have aluminum L98 heads and was considering 1 3/4" SLP headers, do you think they will fit? Did you ever try short header plugs?
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
[This message has been edited by CamaroMike (edited January 18, 2001).]
Old Jan 18, 2001 | 11:21 PM
NOSFEDGTA's Avatar
Thanx for the reply guys. I was also told that the SLP's would not fit my angle plug afr's. I ended up going witht the Hooker LT's and getting them Jet Hot Coated. As for the y-pipe IRS sells one that is only 195.00.
Old Jan 19, 2001 | 08:48 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
PLEASE NOTE: There are differences in ANGLE PLUG heads in terms of the spark plug angle. As long as you have L98 Angle Plug heads thent he SLP headers will fit with ZERO problems. I am running AFR heads with the L98 angle plug and am using SLP headers and everything works great.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jan 20, 2001 | 07:15 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have TF heads with angle plugs. My SLP 1 3/4" hearder clear the plugs no problem.
We won't talk about the steering shaft though
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
83RDRACR
Mar 26, 2016 08:13 PM
redformula88
Oct 14, 2015 06:08 PM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
