Heddman Hedders don't fit the cat???
Old Jan 23, 2001 | 10:42 PM
PullmeoverRed's Avatar
I want the Heddman Headers and Y-Pipe because I've heard that they're good, and affordable, which is a major issue. I've also heard that the y-pipe doesn't bolt on correctly? Is this true? So would I be better off not buying the Y-Pipe and giving an exhaust shop some money for a custom Y-Pipe? I wouldn't be able to have it coated, right? Because I wanted the HTC coating from Heddman. What the hell should I do?
Dave Heinrich
92 Camaro RS
305 TBI
Dynomax Cat-back
K&N
Fully upgraded audio
Need some headers!!!!!!!
Old Jan 24, 2001 | 05:09 AM
taliesian's Avatar
the y-pipe fit my application perfectly, however I do not run cats but I do not think there would be a problem.
installed on 84 z-28,84 trans-am and 88 iroc
Old Jan 25, 2001 | 06:45 AM
RGZWS6's Avatar
If you have the single cat set up like I think you do, then you should be fine. The Headman Y Pipe bolts up just fine --IF-- you cut the old Y pipe off of the cat at the correct place. You should see a little lip where the cat would end when it SLIPS into the stock Y pipe. Mine pipes was so rusted, I had to cut. Double check the cut, not too short, and you should be able to SLIP the new Y pipe on to your old cat.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Jan 25, 2001 | 11:53 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I am thinkin bout getting these myself...
I have 2 84 TAs one of which is about to get a complete overhaul...
nice to know that they fit my cars well...
BTW i think the Summit Headers are actually Headman headers...
later,
Chris
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
nuggie
Aug 25, 2015 01:27 PM
89lsc
Aug 14, 2015 04:58 PM
gta power
Aug 13, 2015 06:15 AM
