How to tightn header bolts on car??
Old Jan 20, 2001 | 01:07 PM
Jas89TTA's Avatar
I have a 87 Trans Am TPI 350 that I had Hooker Headers installed on it. The ones with the AIR pipes. The bolts keep coming loose and I get that ticking noise. What can I use to tightn them up. I used a wrench but it does not seem to help. Is there any bolts that would work that will not back out? I'm getting tired of spending 1-2 hours tighting up the bolts and it not lasting but for a day or two. What do ya'll use to tightn them up?
Old Jan 20, 2001 | 01:35 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Try using Stage8 header bolts. They use an allen wrench to tighten them down and they are locking also. You can get them through Summit for 31.95(STG-8911). It may be pricy but you'll never have to worry about them backing out. Hope that helps.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&R subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jan 20, 2001 | 02:52 PM
Marc 85Z28's Avatar
1-2 hours? It takes me about 5 minutes, and I do it once a month or so. The Hooker's design can't be that different from Edelbrock's. All I use is a 8" long 7/16" heavily offset (about 1/2") wrench, and a 5" long 7/16" flat wrench for the back number 8 cylinder.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Jan 20, 2001 | 03:16 PM
Jas89TTA's Avatar
Thanks, I'm getting a set of those bolts ASAP. I'm tired to doing them. I'm not sure why it takes my 1-2 hours I used a 7/16 wrench about 6" long and It's a pain the one that keeps coming loose is the bolts on the #8 cylinder. Thanks
Old Jan 25, 2001 | 10:38 PM
MeanTA's Avatar
You may want to also consider Lock Tite. I have had some good luck with that but nothing beats locking washers.
MeanTA
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
mustangman65_79
Aug 7, 2015 09:55 PM
