Having trouble with your SLP 1 3/4" headers rubbing? Possible solution inside...
Old Feb 1, 2001 | 08:32 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
This is so simple it's stupid. All the crazy rumors, motor mounts this, motor mounts that... it boils down to one thing.
Move the steering column.
That's right. Three bolts at the bottom of the steering column and the firewall, and two under the dash. Loosen them all. Grab the steering wheel and pull it all the way to the left. Go under the hood and use a screwdriver or something between the header and the steering shaft and shove them apart. Bingo, instant clearance.
Tighten bolts and drive away.
Of course, if you're as unlucky as I generally am, you'll need to oval out the holes on the steering column where it bolts to the firewall. No big deal, really. That sheet metal is so flimsy it really only serves the purpose of holding the steering solumn in more or less the right spot on the firewall. The two bolts under the dash are the load bearing ones.
Can you believe it? All this bull**** and it's this ****ing simple, or at least it was for me. If you've EVER had your steering column out of the car, this might be your problem! Mine was all the way to the right. It needs to be all the way to the left. No wonder my problem was worse than everyone else's.
HTH someone!
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
89fast5oh
Sep 8, 2015 09:55 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
