new headers , now it backfires
Car: 99 Formula
Axle/Gears: 342
Originally posted by Marc 85Z28
Any time you have backfiring through the intake means your firing order is wrong. And since you had to remove the wires to put on the headers...
though, once when i crossed some up i had a backfire thru the exhaust, but check those wires
Originally posted by Mark A Shields
that's not right, there are other factors that cause it, but it does make sense that he crossed some wires up.
Any time you have a backfire in the intake, your ignition is not firing when the piston is at or near TDC on the compression stroke. The backfire is caused from the A/F lighting off with the intake valve open. The only other thing that could cause it is a distributor a tooth or two off. And since all he did was remove the wires... Supreme Member
Car: 99 Formula
Axle/Gears: 342
backfiring can be caused by a lean condition too, ex, timing problesm, choke misadjusted.
also, burnt/cracked wires have done it to me before.
but you're right,with what he has done, i'd check the routing again
well guess what...yall were right! redid the plugs, ....stil didnt work, redid em again, worked perfectly !!! thanks for all your help. header install complete!! also had to replace the damn battery after it was done, guess my car wanted more work done:hail: :rockon: :rockon:
Car: 99 Formula
Axle/Gears: 342
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
