Can you powdercoat Headers??
I have a set of Hooker Headers on my 87 Trans Am and right now they are not coated. I'm pulling the heads off and would like to have the Headers Powdercoated. Will the powder coating last on headers? Does anyone here have powder coated headers? Thanks, Jason
Well yes and no. I had my old Mustang headers powerder coated for free with standard powerder coat and they mostly chipped and flaked. If you use a good hi-temp coating they will last forever though.
'88 Mustang Gt Nitroused 351w/c4
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Typical powder coating that is used in shops or the home kits sold by Eastwood are baked on at 400 degrees. Headers get hotter than that and will melt the powder coating off. Proper coating is ceramic based and will withstand the heat of an exhaust system.
You can powdercoat every other part of the engine including the block and heads if you want with no problems. My Harley engine is completely powdercoated.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
redformula88
Oct 14, 2015 06:08 PM
coat, engine, faucets, handle, harle, headers, kitchen, peerless, powder, powdercoat, powdercoated, repair, single, thirdgen, widespread
