Hooker 2460's and o2 sensor
Old Dec 11, 2002 | 09:22 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i just bought those headers and the o2 sensor bung is there and treaded but it is blocked. they never drilled the hole for it. what is the best way to drill it out. also it seems that the o2 sensor bung is 180 degrees around the header.
Old Dec 12, 2002 | 02:30 PM
CamaroCain's Avatar
Car: 88 Camaro
I just bought the exact same headers, check the instructions, they
say the size drill bit and everything you need to do to them, they leave it blocked in case you dont want to use and o2 sensor, for carb. applications.
Old Dec 12, 2002 | 02:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They put their O2 bungs on the back side for some reason. My sensor wire barely made it, but with some tweaking of the wire in the harness, I was able to make it reach without touching anything.
Old Dec 12, 2002 | 05:49 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
does it cause any harm to a TPI engine if u dont use ur o2 sensor???
Old Dec 12, 2002 | 06:42 PM
five7kid's Avatar
Nah, no harm. Just won't go to closed loop...
Chris Etemadi
May 1, 2001 11:48 AM
CamaroX84
Oct 25, 2000 11:43 PM
