Early model heads + 3rd generation headers???
I'm looking seriously at an '87 IROC-Z that has a bad motor, but otherwise complete.
The car has Edelbrock TES jet hot headers with MAC 3" exhaust. The heads with the motor i'll be putting in are from 70's (double hump style which i'm sure most of you are familiar with).
Will these headers work with the heads i'm using?? I'll be pulling the TPI and all smog equipment.
2001 Dakota
2001 Dakota
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Yes they should bolt right up to the double hump heads.
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
HOOKER LT's SOON!!! & 4 inch Exh.
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Driven Daily
The headers will work fine. The problem is when you used older heads with the 3rd Gen stock exhaust manifolds. The older heads do not have the extra exhaust bolt hole that the manifolds need.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Car: 1990 iroc
Engine: 350 tpi
the concern when it comes to headers and heads is angle plug vs stait plug,intake bolt patern, and accessory holes. tpi intake will not work on the heads you describe. if you have angle plug and you move to strait plug you may have hard time changing your plugs. made this mistake on my chevelle. put trickflow heads on (witch are angle plug) headers were made for strait plug so I had to buy the short plugs and it was still a hard to get to them. it was easier to un bolt the hearder to change the plugs. I think the accesory holes should be drilled in those heads though if they are from 70
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
