?Gain from edelbrock TES?
Old Mar 13, 2001 | 08:16 AM
Steve89GTA's Avatar
#6872 1987 Camaro 5.7L V8 T.P.I. stock:7.91 TES's: 7.61 GAIN:.30
The above info is right off their website.
A gain of .30 something? This Camaro showed the lowest gain of all the cars/trucks tested. WTF, are our stock exhausts good enough? Sounds like a performance resource/fastchip/Jetstage 2 chip would give more power for less $$$
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 13, 2001 | 03:32 PM
Dan87IROC-Z's Avatar
Headers reduced my ETs by an average of about .4 seconds. My Performance Resource chip reduced my ETs by only .2 seconds. The PR chip cost me $200 and the headers were $320.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 16, 2001 | 04:55 PM
vortech305's Avatar
Installing headers on a stock exaust system will do nothing for u. IF u add a complete exhaust system then u should knock out a couple of tenths. Once thats done go for the induction and so on so forth.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 17, 2001 | 05:15 PM
Yes, exactly, I forgot to mention that. Only install a set of headers if you have an aftermarket cat-back system already on the car. The headers and cat-back took my ETs down by .6 seconds.
L98 TPI 350 (5.7L)
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Old Mar 18, 2001 | 10:46 AM
chris83z28's Avatar
Edel. headers dropped my et's down 3 tenths. It was a great mod but a real pain to install. It took me an entire weekend but it was worth it. I gained torque on the bottom end and it make the car sound much deeper and louder.
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, (Edelbrock Performer 600cfm carb.)- went back to q-jet!!! T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
Old Mar 18, 2001 | 06:56 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
A free-flowing 3" cat wouldn't hurt as well...
Old Mar 19, 2001 | 02:17 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hehehe, I like the free-flowing stuff.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 19, 2001 | 09:27 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I didnt go to the track yet but SOTP gain was very appearant. I installed the MSD box at the same time.Let me tell you: WOW,F**king,WOW!!! I'm from the old school of thought;if you gonna do anything to a motor, put in headers first and foremost. Than again these "newer"(EFI) motors have a lot of "free mods".
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46)
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
efiguy
Sep 27, 2015 01:30 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Night rider327
Sep 25, 2015 04:47 AM
