Hooker cat-back from Jegs?
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
I'm going to be getting the hooker cat-back from jegs and I was wondering if anyone else who has gotten this from them if there's been any problems with it? Thank you!
Justin
Justin
I have been very happy with the Hooker Aerochamber cat-back system I bought from Jegs last summer. My friend also bought one for his 85 Z28 and he has had great success with it. You will need to get a long bolt with a nut to mount the passenger side of the system to the hangers, you could also use a coat hanger. I used the coat hanger to begin with and the over the axel pipe was resting on the suspension, so I got the long bolt and now it fits perfectly! You'll be very happy with this system, its money well spent!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
no green
Jan 9, 2016 09:22 PM
Chevykid810
Sep 28, 2015 12:57 PM
