shut car off... exhaust makes pinging noise..??
Old Dec 18, 2002 | 01:07 PM
89formula4life's Avatar
well the subject speaks for itself... its been doing it since i got the car almost 2 years now.. doesn't really bother me, not really loud or anything, just curious as to what it is... thanks Corey
Old Dec 18, 2002 | 02:16 PM
big_ty2003's Avatar
It is just the metal expanding and contracting due to the sudden change in temp.
Old Dec 18, 2002 | 02:19 PM
fattie92's Avatar
geat some headers and the noise will go away.
Old Dec 18, 2002 | 08:07 PM
i knew it wasn't anything to serious.. thanks
Old Dec 19, 2002 | 12:00 AM
iroc22's Avatar
It's actually the catalytic converter cooling down. The converter has to be very hot during operation to work properly; so it actually ends up being hotter than the rest of the system and as mentioned above, the metal is contracting as it's cooling down. The only way to get rid of it is to remove your catalytic converter.
Old Dec 19, 2002 | 10:05 AM
hndsm17's Avatar
...thats good to know although i should have been told this a few days ago because i burned my forarm on a cat when i was changing its oil on some hyudai or whatever at work.....it isnt too pretty
Old Dec 19, 2002 | 10:06 AM
hndsm17's Avatar
now i know to always keep your sleeves rolled DOWN when going near the exaust of any car thats been on te road for a while, and to refer to the topic, yeah every car, new, or old will make that noise depending on if its humid, cold, and whatnot...just dont touch it like i did accidentaly :lala:
Old Dec 19, 2002 | 02:17 PM
big_ty2003's Avatar
Its not the catalytic converter, I dont have one
Old Dec 19, 2002 | 03:42 PM
Marc 85Z28's Avatar
You're right - its not the converter. It's the flanges and flange bolts on the exhaust. And ALL cars do it BTW - some more than others.
Old Dec 19, 2002 | 08:26 PM
iroc22's Avatar
Funny - Since I've never heard a cat-less car make the same pinging sounds as the ones with them. Honestly. And trust me, I've been exposed to many muscle cars and street rods that do not have catalytic converters. I'd have to hear it to believe it.....
Old Dec 20, 2002 | 12:27 PM
fattie92's Avatar
yeah i dont have a cat... thats y i thought that the headers and new exhaust got rid of that problem....but the cat theory makes sence
Old Dec 21, 2002 | 09:01 PM
Marc 85Z28's Avatar
I've never listened to any other cat-less cars cool down before - at least not to listen for any noise. But my car currently has just a straight pipe, and it still does it. It depends on how hot the exhaust piping gets - and a cat really boosts the temps
Old Dec 21, 2002 | 10:22 PM
82camaro's Avatar
Car: 82 camaro SC
The cat helps things along with the added heat. Also, running header wrap can add some exhaust heat to the pipes. If you run a fully welded system, you probably won't have much if any noise at all.
Old Dec 21, 2002 | 10:38 PM
fattie92's Avatar
my set up is all clamped togeather. headers and a catback....no noise... i think that its just anything stock.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
