Dual Exhaust Pics
Old Mar 27, 2001 | 01:53 PM
Kenn's Avatar
Dual Exhaust Pics
But I need help posting it - can I email them to one of you guys to post- thanks
Old Mar 27, 2001 | 01:54 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
I will post it if you mail it too me.
"I don't trust anything that bleads for five day's and doesn't die"
88 iroc slp headers,borla catback,procharger to come soon.
Old Mar 27, 2001 | 02:29 PM
Kenn's Avatar
Its not working gearrrhead I tried three times
Old Mar 27, 2001 | 03:33 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
here you go
Old Mar 27, 2001 | 03:54 PM
Kenn's Avatar
thanks alot gearrrrrrrrrrrhead
I know I got a LOT of explaining to do but right now I gotta go
thanks again!
355TPI, AFR 190 58cc, Edelbrock base runners, Crane 1.6rr, BBK 52mm, Hooker long tube headers, X pipe 24LB inj, LPE 219 .525 lift tremec, 3.08 Richmond gears and a Century 131 135 amp cordless MIG welder
[This message has been edited by Kenn (edited March 28, 2001).]
Old Mar 27, 2001 | 04:35 PM
Guest
Guest
Posts: n/a
Interesting. No way to keep the torque arm in there?
Old Mar 27, 2001 | 05:24 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
How's it sound? I've heard dualed 3rdgens that have sounded like crap. I would like to have a nice sounding dual system!
91 RS
Black w/ red tweed
t-tops
14x3 Open Element
80 Series Flowmaster
350TPI or Buick Turbo6 swap this summer
88 GTA
Red with grey cloth
K&N Filters
TPIS Airfoil
Old Mar 28, 2001 | 07:38 AM
Kenn's Avatar
I've seen the stock torque arm in place on another dual exhaust set-up on this board but when I tried it I couldn't get the ground clearance I wanted - and I like my homemade ladder bars a WHOLE lot better - it has the same Anti-Squat of running a T/A with LCA relocation brackets, it feels more stable at hwy speeds and corners better imo - basically it seems as if I have two tiny little torque arms at each wheel - but a 20 inches long they plant the tires a lot harder than 40-50 inch TA
The 1.75 in Hooker Headers fit great - no problems with the slave cyl or the oil filter - I put the heated O2 sensor on the side of collector instead of the the reducer because its less of an obstruction to flow there - otherwise both positions work fine
The transmission crossmember is the first thing I made when I decided to do this - its made from 3/16in 90 degree angle iron (mounting flanges), 0.25 in flat steel and 0.75 in black pipe all from Home Depot- I trimmed the excess metal for weight saving - it only took two tries to get that right
The X-pipe and most of the piping was made from 16 guage mandrel 2.5 in U-bends chemically stripped and painted - the X-pipe has a 1 3/8 X 2 1/2 in oval hole connecting the two - that brown stain on the X-pipe is $6 a qrt GM Synchromesh Synthetic Automatic Transmission fluid from the rear seal of the Tremec- b i g p i t a
Not in the pics but the fuel lines in the tunnel have been relocated upward about an inch - real easy to do since two brackets in series hold them to the body - I just removed one and bolted it up
Over the axle the pipes are supported using U-bolts and heavy duty exhaust hangers secured with the gas tank strap bolts - over the axle pass and dr side are essentially the same except the rear brake line splitter is relocated away from the pipe - and out the back with Dynomax Bullets and turndowns
Two things I want to do is install new rear brake lines and weld the splitter to the axle tube and either make a Panhard Rod Bracket Support Rod to clear the dr side pipe OR solidly weld the Panhard Rod Bracket to the frame - the bracket is pretty strong though.
I finished this two weeks ago and after tuning and all it sounds deep and choppy- the throttle response is incredible this engine wants to run but the custom Hypertech prom for the single exhaust wont let it - it idles best at 46psi which gives 750-850 mV and 1.6=/- pulse widths but at 3-4K RPM it leans out. I'm gonna get another custom prom and I'm hoping with all the low end torque producing mods- LT headers, LTR and X-pipe - I should be able to port the intake a little, get a Hydra Rev then start making good power at 6200rpms+ and still have some low end grunt left over
we'll see
Old Mar 29, 2001 | 11:06 PM
superz's Avatar
a tremic tranny huh? how do u like it? its a 5 speed right? what is it rated at for torque?
[This message has been edited by superz (edited March 29, 2001).]
Old Apr 2, 2001 | 09:12 AM
Walls's Avatar
are your headers shorty style or not????
If there long tube did you run into floorboard clearence problems?
if not let me know i need new headers?
what type do you have, how much, and where to get them would be helpfull!!
you can email me at whitewalls85@hotmail.com
if you wish
Old Apr 2, 2001 | 09:13 AM
Walls's Avatar
if you wish
Old Apr 2, 2001 | 04:21 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
Ken, If you get a chance, shoot me over an e-mail, I have dual 3in, but with no tailpipes. I am interested in how you set up the ladder bar setup. I have a few more questions also.
Thanks,
Brit
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...12.90 @ 112.5 with a 2.3 60ft time on BFG radial TA's
Old Apr 3, 2001 | 01:31 PM
Kenn's Avatar
The Tremec is pretty good especially the 3.27 first gear with my 3.08 rear (econo) gear ratio - I can launch without too much spin and still cruise at 70mph around 1800rpm
rated at 525 ftlbs Tq capacity
I have Hooker Long tube Headers 1 3/4 inch primaries no fit problems whatsoever- Jegs $380
Bowtiroc all the rear suspension parts (and most everything else for that matter) are homemade the ladder bars have to be used with LCA relocation brackets to create the extra mounting hole at the axle- I can draw up the blueprint and send it to you no big deal
how are you planning to run the rest of your exhaust?
look at these posted by 88blkiroc https://www.thirdgen.org/messgboard/...ML/001118.html - kinda interesting
Old Apr 21, 2004 | 03:14 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
Transmission: 700-R4
rear suspension design
Hi Kenn,
I am interested in doing a long tube header install with dual exhaust, the pics in this post are no longer available and you said in your last post that you could draw up blueprints. If you still have these pics or could draw up the blueprints, I would really be interested. You can contact me at IrocZS427@yahoo.com, or Iroc357@aol.com. Thanks David
Old Apr 21, 2004 | 05:47 PM
chad89ta's Avatar
hey guys i got three inch duel setup that i have some pic of i would like to show them to you email me and ill send,i got full leanth hooker headers part#2210,i had to make a costom x member,then where the back seats are i cut out and made a box to fun the flowmasters then its dumps,best sounding third gen ive heard,then again the car runs 11.30s,www.provgolf4u@aol.com[/email]
Old Apr 21, 2004 | 11:39 PM
Xhiron's Avatar
Car: traded away 94 v6
Engine: vacant
Transmission: also vacant
Hey Kenn, would you be willing to discuss your ladder bar setup with me? I'm extremely curious on how you built it, if you could email me Xhiron@Hotmail.com and tell me abou tit I'd be very grateful.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
