mufflex 4" exhaust?
Old Mar 29, 2001 | 08:35 AM
ADV1's Avatar
mufflex 4" exhaust?
Does anybody have this or know anything about it? I called out to the mufflex office to get a brochure and some info and the guy was kind of a jerk. He told me to go online, so I did and over the last 6 months there web site hasen't worked. I'd really like some info and possibly a sound take if anybody has one. Thanks...
1984 CAMARO BERLINETTA
355 HP VORTEC HEADED 350
350, Vortec heads, Crane High energy cam, edelbrock Air Gap intake(for Vortec heads!)
Pete Jackson gear drive, 9.5:1 comp, Edelbrock TES headers, high flow Cat, custom exhaust,
Hypertech HEI, Custom built 700R4 tranni by S&S Performance Transmission
3.73 10-bolt(soon to be 9bolt with rear disk) 2 3/4 cowl induction fiberglass hood.
Old Mar 29, 2001 | 09:52 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I have the 4" Mufflex system. It fit reasonably well, and is of pretty good quality. It sounds extremely tough. It's pretty loud if you don't run cats. It's pretty loud, period. It's got a real deep rumble at idle and screams when you get on it. NASCAR style. I think you talk to someone in the shop if you call there. They are usually busy and frustrated. Try calling at another time of day. I'd make a sound clip but am unsure what to record it with. A very impressive system.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 29, 2001 | 11:45 AM
RoadRacin85Z's Avatar
I've been looking into this exhaust system, and I believe that it is right below $500 from Mufflex. The 3.5" system is $450 for the single cat cars, and $425 for the dual cats. The website has worked for me the past couple days, they have some sound bytes (but not of the single 3.5" or 4" for the third gen). http://www.mufflex-performance.com
-Joel Likness
- 84 Z28 In Progress
Road Racer
- 85 S10 350/350
Drag Racer
- 85 Nissan 200SX (yes, it's Japanese)
Circle Track Car
- 91 Lumina 3.1 Euro
Daily Driver
Old Mar 29, 2001 | 11:46 AM
Oh, and the muffler is either a Flowmaster Racing muffler (not sure what series), or a Spintech muffler, it's your choice, same price. I'd like to hear the difference between the two personally, but I think the Flowmaster would be a little bit quieter...
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Old Mar 29, 2001 | 11:55 AM
ADV1's Avatar
So when you mount the exhaust on your car is there somekind of a choke on the part that connects to your cat? or do you need to find a high flow cat that is say 2 1/2 in and 4" out? I've got the Edelbrock TES system on there right now and I believe the Y-pipe connects into a single 2.5 collector. You wouldn't happen to have any pics would you? On a 1-10 scale where would you rate the system as a whole, ease of install and sound? I know that sounds like alot but I'm very interested in this and $500.00 aint cheap. Thanks for all of your help...
Old Mar 29, 2001 | 12:03 PM
ADV1's Avatar
One more thing, can you even hear your stereo with that system installed? How bad in the resenance inside the car? Both idle and WOT
Old Mar 29, 2001 | 09:31 PM
steve8586iroc's Avatar
AVD1, I noticed in your sig that you are running the RPM Air Gap and Vortec heads. How close is the top of the carb to the top of the hood? I'll be using the same set up with a tbi and a 1/2" adapter plate so I was just curious as to hood clearance problems. I expect mine will probably hit the hood without the air cleaner on, I guess I'll find out soon enough.
Steve
Old Mar 30, 2001 | 08:01 AM
Engine: 406
I have 1.75" SLP headers made for a dual cat car. At the ends of the two pipes, I have Flowmaster Venturi Cone 2.5" to 3" adapters. This is to a Flowmaster y-pipe with dual 3" inlets and one 4" outlet. The rest is stock Mufflex. The mufflex is 4" all the way up to about the transmission. It then steps down to a 2.5" or 3" pipe to attach to the cats. To really get the full benefits of a large exhaust, you may want to eliminate some of the bottlenecks.
As far as sound on a scale of 1 to NASCAR, I would have to say NASCAR. 10. It sounds bad. Bad as in good, of course. It shakes the windows in my house at idle. Idle is a great low rumble. It gets pretty loud when you step on it. I can listen to my stereo and talk to my friends without yelling. I've driven it to Florida twice and multiple other long trips. No complaints. Interior resonance is pretty bad in my car, but I also have everything solid mounted. That is soon to change. Multiple people have asked if I have a big block in my car.
Overall, quality 1 to 10, 9. Pretty nice. The muffler is a 4" in/out 2-chamber (40 series?). I'd like to see/hear their new dual 4" out Spintech system.
Old Mar 30, 2001 | 08:48 AM
ADV1's Avatar
Steve, htere is actually a story behind the ol air gap thing. I returned it, When I bought it there was no picture availablr and the schmo who sold it to me told me it would owrk with a Rochester Quadrajet(spread bore) well guess what...it doesn't and they don't make one either. I do however use the Edelbrock Performer RPM unit and I do like it but I really wanted that air gap manififold for that "COOLness" factor.
I really can't answer your question on hood clearance as I'm using a 2 1/4 Cowl induction hood. I can say this though, with the Performer RPM, the carb and a 4"tall K&N open element air filter on top I have about a 1/2 inch clearance to the bottom of the hood.
My problem now is that I want to put a 1" carb spacer in there to see what that does to help my bottom end torque. So I'm going to have to get a 3" tall filter to replace the 4" in order to fit.
3RDGENFRANK: Thank you so much for your help on this exhaust delema I had. I have made up my mind and I'm going to get this unit. I will have to see what I can do to get rid of some of those bottlenecks you were talking about. I really want to keep my cat to make everything work right and so I'm going to have to do some fancy plumbing. Thanks again!
Old Mar 30, 2001 | 12:23 PM
Engine: 406
Random technology makes a 4" cat if you are interested. Otherwise, two 2.5" or 3" cats will probably do the trick. I will put cats on my car as soon as I'm done tuning. I didn't want kill new cats while I dial in the motor. Cats also make the exhaust sound even deeper and a little more civilized. Good luck!
Old Mar 30, 2001 | 06:17 PM
AVD, I kinda thought you had a cowl hood or something like that. I will have to figure out witch way to go when I cross that road. I want to make a shaker type hood scoop. Maby a cowl hood scoop converted to a shaker. Would that look to stange or just stupid? I'll have to do something, I just don't want something everybody else has if I don't have too.
Steve
[This message has been edited by steve8586iroc (edited March 30, 2001).]
Old Mar 30, 2001 | 06:41 PM
bad camaro RS's Avatar
heres how i did my mufflex love the sound nice fit
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Mar 30, 2001 | 06:43 PM
4" mufflex system
Old Apr 1, 2001 | 05:20 PM
bad camaro RS:
How much ground clearance do those Hooker long tubes eat up? I like how you've got that setup run, and I like long tube headers, but I'm afraid they'll just eat up way too much ground clearance...
Also, don't they make a 1 5/8" Competition (not Super Comp)? I wonder if they have the same ground clearance issues...
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Old Apr 2, 2001 | 05:28 PM
ground clearence isnt bad i dont drag on anything yet id say ive got 2-4" of clearence at least " sux at guessing" but i like it anymore ques jus fire away
4" mufflex system
Old Apr 3, 2001 | 02:21 PM
Hey man -
Just checked out your homepage, and that car looks awesome! More evidence that black is the best color for a third gen...
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
david068513
Sep 18, 2015 10:36 AM
